NitroDann's Long Awaited Garage Thread
gslender
Re: NitroDann's Long Awaited Garage Thread
Postby gslender » Sun Apr 28, 2013 5:16 pm
Makes me want to buy an SE and have Dann install a new turbo and zorst, and I can build a MS3 Pro harness and develop a base map etc.
Mmmmmmm.....
G
PaulF
Postby PaulF » Sun Apr 28, 2013 5:37 pm
Why not turbo the track beeotch?
rxmx
Vehicle: NA6 - Turbo
Postby rxmx » Mon Apr 29, 2013 11:59 pm
Looking forward to seeing how much boost/torque this thing makes down low
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Postby NitroDann » Tue Apr 30, 2013 12:00 am
I imagine thats a challenge? :mrgreen:
how far away is your EFR'd miata?
rxmx
Postby rxmx » Tue Apr 30, 2013 12:10 am
certainly not lol, im running slightly bigger 6758 so id expect this thing to come on a bit sooner. Hopefully be running by end of week. Dyno graphs of efr setups just have win everywhere just looking forward to seeing what these turbo's are like to drive behind
Postby NitroDann » Tue Apr 30, 2013 12:22 am
This unfortunately has a stock bottom end still and a 14psi actuator so it will be wastegate wired open for a little while I think :(
Postby NitroDann » Tue Apr 30, 2013 3:39 pm
Coming together, got some time to do a little this morning before I had to go.
Muffler tucked RIGHT up and nicely centered. Note that this is still only tacked so the welds (mostly the heat colouration around them) look patchy, thats why.
Not 110% happy with the tip so Im redoing from the muffler outlet back.
I do like how you can JUST see the muffler if you kneel, it looks very OEM.
Whats this we have here? SE owners will recognise this manifold and heatshield?
BOO :twisted:
Off to the race ceramic coating shop tomorrow.
deviant
Postby deviant » Tue Apr 30, 2013 3:43 pm
I fapped.
MrRevhead
Postby MrRevhead » Tue Apr 30, 2013 4:06 pm
I've always been a fan of the stealth/sleeper look.
Great work Dann!
Sean
Postby Sean » Wed May 01, 2013 1:51 am
Your best work yet man.
Whack some nut and bolts through those spare holes and it's be flawless!
gslender
Postby gslender » Wed May 01, 2013 8:28 am
Sean wrote:Your best work yet man.
For the uneducated in SE components (like me) can you outline what is different between this and the standard/stock header? Perhaps a photo with them side by side or at least a similar pic - which might help illustrate the benefits gained here.
Postby Lokiel » Wed May 01, 2013 10:01 am
The MSM/SE uses a small IHI turbo (vs the better SP's GT2560). Here's the SE manifold:
Top one is BEGI or FM Log Manifold, bottom one is the SE/MSM manifold
Postby NitroDann » Wed May 01, 2013 10:28 am
The stock manifold has a few flaws.
If you look above the very top pic isn't the Se manifold but the others are.
You can see how cylinder 1 2 and 3 a share a runner so by the time it hits the collector you have 3/4 of the engines exhaust fighting to get out one small runner full of casting marks and then go head on into the cylinder 4s exhaust gas and with nowhere to go turn 90* and head out the turbo flange.
It's a log manifold in the simplest form and if it had a T28 flange and the flange was positioned correctly many would go to a T25 or 28 as a cheap upgrade that spools better and makes far more torque through the mid all the way to 8000rpm.
However it doesn't have the T28 flange nor is that flange positioned right, so the manifold I made has individual runners that turn together to form a collector rather than the runners aiming directly at each other an pressure alone pushing them out the collector instead of into each other.
Oh and unlike the Se manifold this one has the right flange for and is positioned to fit a 440hp Borger Warner EFR :twisted:
corners
Vehicle: ND - Supercharged
Postby corners » Wed May 01, 2013 10:42 am
Postby Okibi » Thu May 02, 2013 1:32 am
So when does the kit go into production? :mrgreen:
