NitroDann's Long Awaited Garage Thread
Re: NitroDann's Long Awaited Garage Thread
Postby NitroDann » Fri Apr 26, 2013 11:19 pm
Ah it is supposed to say 'stand up to it'.
Autocorrect.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Apr 26, 2013 11:42 pm
can vouch for Danns hanger welding, good enough is definitely not good enough for Dann.
Postby Okibi » Sat Apr 27, 2013 4:45 am
So sexy, would love this on my SE :mrgreen:
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Sat Apr 27, 2013 8:50 am
The double hanger is a very good idea. My hanger just ripped out after 6 track days.
Postby Lokiel » Sat Apr 27, 2013 3:48 pm
deviant wrote::
Seriously I would consider not revealing any more on this until it is finished and then patent the design. As far as I can see nobody else is doing anything like this?!
There's a couple of guys in the US that specialise in this sort of work for MX5s/Miatas.
When I started looking into the EFR6258, I realised that I'd need a custom manifold and exhaust - there were no off-the-shelf solutions and the Trackspeed Engineering kit that was supposed to be available at the end of last year is still nowhere to be seen.
"Turbo Tim" from ARTech Fabrication (see http://www.artechfabrication.com/NB--99-05-.php) in the US is a MX5 fabrication "specialist" and I was tempted to get him to do the work. Unfortunately S&H large items from the US is expensive - I learned this when I bought my FM MAZDASPEED 2.5" exhaust; S&H was almost as much as the cost of the exhaust itself so I wasn't keen on dong that again. There are also other LHD vs RHD issues that may have caused problems.
I'd been following Dann's thread here and was impressed with his progressively improving welding skills and the fact that he takes so much pride in his work and really goes out of his way to keep customers satisfied -just ask anyone he's built stuff for.
Dann jumped at the chance to install the EFR6258 and we discussed what options were available. I'd rather do things properly the first time since that's usually cheaper in the long run anyway, and much less grief, so I took him up on all of his suggestions (eg. ceramic coating the manifold). I'm very impressed so far at what he's built and daresay that it's at least comparable in quality to ARTech fabrications.
I can't wait to hear what the exhaust note sounds like.
At the risk of damaging Dann's "street/forum-cred", in person he's NOT what I expected based on the forums, he's a pretty good bloke and very easy to deal with - many businesses could learn a thing or two from him about customer satisfaction.
bootz
Postby bootz » Sat Apr 27, 2013 5:34 pm
Wow, this is going to take the build thread to a whole new level.
Sean
Postby Sean » Sat Apr 27, 2013 10:55 pm
Lokiel wrote:At the risk of damaging Dann's "street/forum-cred", in person he's NOT what I expected based on the forums, he's a pretty good bloke and very easy to deal with - many businesses could learn a thing or two from him about customer satisfaction.
LOL.
Zorst looks good mate - Should see pretty nice results - Love the stealth install too.
gslender
Postby gslender » Sun Apr 28, 2013 5:16 pm
Makes me want to buy an SE and have Dann install a new turbo and zorst, and I can build a MS3 Pro harness and develop a base map etc.
Mmmmmmm.....
G
PaulF
Postby PaulF » Sun Apr 28, 2013 5:37 pm
Why not turbo the track beeotch?
rxmx
Postby rxmx » Mon Apr 29, 2013 11:59 pm
Looking forward to seeing how much boost/torque this thing makes down low
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Postby NitroDann » Tue Apr 30, 2013 12:00 am
I imagine thats a challenge? :mrgreen:
how far away is your EFR'd miata?
rxmx
Postby rxmx » Tue Apr 30, 2013 12:10 am
certainly not lol, im running slightly bigger 6758 so id expect this thing to come on a bit sooner. Hopefully be running by end of week. Dyno graphs of efr setups just have win everywhere just looking forward to seeing what these turbo's are like to drive behind
Postby NitroDann » Tue Apr 30, 2013 12:22 am
This unfortunately has a stock bottom end still and a 14psi actuator so it will be wastegate wired open for a little while I think :(
Postby NitroDann » Tue Apr 30, 2013 3:39 pm
Coming together, got some time to do a little this morning before I had to go.
Muffler tucked RIGHT up and nicely centered. Note that this is still only tacked so the welds (mostly the heat colouration around them) look patchy, thats why.
Not 110% happy with the tip so Im redoing from the muffler outlet back.
I do like how you can JUST see the muffler if you kneel, it looks very OEM.
Whats this we have here? SE owners will recognise this manifold and heatshield?
BOO :twisted:
Off to the race ceramic coating shop tomorrow.
deviant
Postby deviant » Tue Apr 30, 2013 3:43 pm
I fapped.
Users browsing this forum: Bing [Bot] and 40 guests
