What ECU for my SE
Re: What ECU for my SE
Postby Lokiel » Mon Apr 29, 2013 1:37 pm
sailaholic wrote:I can share on adaptronic. It's not a se unit but does use inputs for load triggering due to fan lights ac ect to increase the idle value.
My idle at this stage works, but is not factory level and does sometime take a while for the ecu to figure out its base level setting are right and then adjusts. I should go back and try and tune this problem out but I'm short on time and have some other gremlins I'm chasing.
Having said this, itbs and bigger cams probably don't help the idle characteristics.
I also agree with Tim k that that idle and (for me light throttle) are the tricky / annoying / expensive parts to get right.
Seeing as we are both bayside we can probably arrange something where you can have a look at the unit in car. I'm even open to a short term ecu swap. I've configured mine to run 4 ign and 4 inj channels though so not sure if it would be that easy to swap a MS in?
Why not let the OEM ECU control Idle?
The Adaptronic provides jumpers for this - Norwegian mazda-speed.com member "lassi" found doing this using the map that I provided him from my e440 Select ECU that it idled MUCH better. MAZDA has already put lots of time and money into this so why not continue using it? I switched to Factory Idle too and agree that it's much better.
See http://www.mazda-speed.com/forum2/index.php/topic,24675.0.html for Adaptronic e440 Select ECU install into an SE/MSM.
With enough tweaking, the Adaptronic could control Idle at "factory levels" but I'm time-poor so am happy top lt the OEM ECU control Idle.
sailaholic
Postby sailaholic » Mon Apr 29, 2013 3:16 pm
G,
I see what your saying, probably better to do more in person but in my case the ecu came with a most of that idle values per programmed. I avoided a fully DIY solution because I bought the car with a megasquirt (pnp) and found it lacking and because I wanted tuner support to get a good tune on the dyno.
Tim, it's a 440 select (universal) which runs the the same plug and pin outs as a na8.
gslender
Postby gslender » Mon Apr 29, 2013 7:09 pm
Lokiel wrote:Why not let the OEM ECU control Idle?
That's a good solution - but what about other aspects like CEL lights and transition from idle/lift-off? I'm not 100% comfortable with a "shared" piggy-back solution for ECU. I don't fully appreciate the technical details behind what Adaptronic are controlling vs when the factory ECU is taking control - so it is hard to know if this is better or worse than a fully standalone solution. Rarely is it better.
This only further highlights that expecting to be able to rock up to a shop and get them to install an ECU < $3000 with a really top tune is probably unlikely. Even the thread linked above goes for months and months before someone stumbles onto the correct temp curves, idle strategy and base map that is reliable.
A specific post in that thread outlines how a customer bought an ECU and had it installed, only to have all sorts of issues that he had to resolve by resorting to a forum to get help! http://www.mazda-speed.com/forum2/index ... #msg293539
None of that rings true to the "I'm gonna buy a XYZ brand ECU from shop ABC so I know it will be right" mindset !!
Best option would be to buy something that has a great big community behind it...!!
G
Sean
Postby Sean » Mon Apr 29, 2013 7:20 pm
Firstly, reading back over this it reads to me (even as the poster) that some of my posts are negative - That's nit my intention. I'n trying to remain unbiased having used a few different aftermarket ECUs, none of which were MS.
Maybe I'm being a little devil's advocate :twisted:
With that out :
gslender wrote:All aftermarket ECUs are pretty much designed for off road/track use. I'd go as far as saying that racing is the primary reason these ECUs are being used for, as such, things like AC idle up/CEL illumination for faults/advanced CL PID idle etc are things that very few if any race engines need.
In light of this, you should be thinking that it isn't always true that a plug-n-play harness and base map/tune will support anything more than starting the engine and getting you to the Dyno.
Again, I think this is hard to quantify. Many aftermarket ECUs advertise the fact they have been used to pass emissions on XYZ car - to me that's a good suggestion they are marketing to people other than race car owners. I concede most people who modify aren't chasing better economy, rather they want better performance - Performance is often a compromise, so perhaps that's why not many people complain about their ECU?
gslender wrote:This is why I'm keen to hear from people who are actually prepared to share the true costs and effort involved with configuring their MX5 SE and are prepared to talk openly about how those extra items were accommodated - eg. how does the idle cope when you yank on the steering wheel and the steering pump dips the RPM... in the stock engine, it would barely be noticeable - but for an ECU configured for steady state warmup PWM idle, the engine would noticeably dip and hunt until the idle stabilises again. What about turning on AC, Fans, Lights etc... how does the idle perform? What about the CEL and other O2 closed loop fuel trim - how is that being accomplished?
I was surprised to hear the haltech in the wasn't quite spot on - It's funny that it appears there is a tuner who knows how to fix it but a personal issue with that tuner means the issue may not be resolved, to me that's a bit like the MS situation where the only expert on them seems to be you G!
gslender wrote:I know how to configure and this all can be done on the MS2 and MS3 ECUs - what about all the others and who did them?
This is my point, you're one dude supporting the whole deal and as far as I know it's a hobby rather than an official gig or money making venture for you. That's great and it's genuininely good we have someone like you around to keep challenging the norm and helping people out, but when you can't quite get it, or have better things to spend your time on things can be not so great - Look at the recent guy who bought one and had issues and even with your help and Dann's has decided to not bother with it>?
gslender wrote:If you have a base-map from a Haltech or Adaptronic, that can be read by downloading the tuning software (or a text file) I'd be keen to look at it. I doubt they have anything setup for those things above I mention. Anyone keen to share?
G
Nice idea, I still love PNP adapters cause I've seen them work well in MX5s, RX7s and WRXs time and time again, but the validity of a true PNP solution will also rest with what mods have been done to the engine - Accepting this is somewhat of a moot point if we are talking about back to back comparo on a stock SE.
All of this said, my NB idle hunts and carries on worse on a stock ECU with no mods than any of the three NAs with aftermarket ECUs I've owned. Could be the lack of attention I pay it though...
For a what ECU topic there's some good info in here. You're development with MS has certainly brought some interesting and enlightening conversation to the forums in a few topics 8)
Postby NitroDann » Mon Apr 29, 2013 7:30 pm
Who is to say Elitee would have fixed his problem if it were an adaptronic or haltec or motec?
Whos to say he could have afforded any of those solutions (not baggin ghim just making a point.).
greenMachine
Postby greenMachine » Mon Apr 29, 2013 9:55 pm
The Haltech E8 I mentioned above spent many years in the GreenMachine running a big HP atmo engine, built for dual road/race duty. It lived in the Canberra area, and those who know the area know that cold start can be an issue with temps regularly down to -8 or worse.
The tune in my car showed none of the problems talked of upthread. Cold start was not a problem, though that took a couple of goes. It ran the alternator without problem. A/c, powersteer caused no problems, and note that this was a daily driver for part of this time, doing 40,000 kms/year. In that time it took a CAMS NSW Supersprint Championship (1st in 2B, second in Type 2) and did a 2.59 at Bathurst, not to mention sundry Club trackday awards.
This E8 was tuned by two tuners, one in Sydney and one in Canberra, both tunes being done early in the piece and then left alone. Both were very carefully selected by me, including a lot of research and talking to others.
One key step i took was to attend every tuning session. I watched, 'drove' the car on the dyno, and asked lots of questions. I also knew what I wanted, and I was careful to set this out as what I wanted from the session, and confirmed during it. Other than a session experimenting with intake configurations, I would have spent well under $1k on tuning, probably closer to $5-600 (that was back in the early-mid2000s).
If that engine had not dropped a valve a few years ago, it would still be running that tune, only it, and the engine, would be in the racecar now.
That is my story, make of it what you will.
:mrgreen:
Sean
Postby Sean » Wed May 01, 2013 12:38 am
NitroDann wrote:Who is to say Elitee would have fixed his problem if it were an adaptronic or haltec or motec?
No-one, just illustrating the support point of view - Many shops know how to diagnose problems with the better known brands, and some offer free bench testing of their units - so he'd know if he had a working unit.
Price aside, is it good value if you can't get it to work? Yeah, I know, there's a good chance he is using the wrong impedance injectors etc etc, but the two experts here (being you and G) had vastly differening opinions on what the setting should be or were to get it to work.
Again, don't get me wrong - if I were to need an ECU for my MX5 and had to pay retail, I'd be speaking to G and going MS.
gslender
Postby gslender » Wed May 01, 2013 6:43 am
Sean wrote:No-one, just illustrating the support point of view - Many shops know how to diagnose problems with the better known brands, and some offer free bench testing of their units - so he'd know if he had a working unit.
Just to clear a few things up....
I bench tested and confirmed the MSPNP2 he has is 100% working fine. It is all solid state electronics on a multilayered SMD board with no user soldering/assembly - much like a Haltech or Adaptronic. So whilst it was shipped working, I take the extra effort and care to confirm the unit is 100% before folks get them. As such, I'm very confident there is no problem with the MS2 he bought. It was even supplied with a suitable map and startup settings for his model engine. He never mentioned different injectors until he installed it - so that bit of information normally would require just a change in ReqFuel and perhaps dead times.
The discussion on differing settings really had no bearing on the running of the ECU in his configuration - I can only assume you are talking about the number of squirts setting (which isn't used for sequential injection) but when people are scratching their heads trying to diagnose problems they will sometimes focus on less obvious things that might be different between running configurations (which end up being irrelevant as it was in this case).
As for support - Dann volunteered his time for free (which is pretty nice) and I've also offered to travel and fix this for the customer (for far less than the price of replacing the MSPNP2) but alas he seems to have changed his mind on a DIY install and now wants someone local where he can just simply drop off the car and collect that evening with a perfect running tune. I'm not convinced it is as easy and simple as that, and that the significant extra being spent on a new/different ECU plus the additional installation might not leave him with the perfect running engine he thinks he's going to get. This view has been confirmed by other experiences I've seen other folks have with similar popular brand ECUs mentioned here in this thread.
Oh, and another bit of information has surfaced whereby the fuel pump was replaced - and now it isn't working either... so I'm somewhat unsure if there is not a greater issue at play that clearly needs the attention of a suitably experienced expert.
I'm chasing up a suitably experienced MS2/3 expert in his area and will pass on their details too.
The reality is that everyone who decided to embark on an aftermarket ECU needs to be prepared for a) learning a little about computers and auto-electronics enough to trouble shoot wiring, relays, voltage drops, sensors, software upgrades etc, or b) expect to keep suitably experienced expert employed for a decent while to iron out all the bugs. You can't muck around with the engine and wiring of a stock car, and then plug-in a brand X ecu and expect it to magically self update and tune itself plus fix all bad wiring, silly engine mods or correct the failed injectors you've bought.
G
Postby Lokiel » Wed May 01, 2013 10:18 am
gslender wrote::
G
+1
Installing an after-market ECU does NOT "auto-magically" fix everything, tuning your ECU is based on the car's current configuration and takes time (significantly reduced if you get it done professionally) - if you make any changes, you'll most likely need another tune/tweak.
Even if you do get your car professionally tuned, they will typically ask you to bring the car back after a week or two so that you've had a chance to drive it and discover any additional problems that need to be resolved (usually free, they build this cost into your initial bill).
You may never get the car to be 100% factory-smooth, those last few niggles can take a while to resolve (mostly through trial and error) and the more you learn to tune yourself, the more likely you'll be to fix these issues.
kenson
Postby kenson » Sun Jul 07, 2013 10:49 pm
DIYAutoTune looking for a SE (Mazdaspeed Miata/MSM) in the US:
http://www.miataturbo.net/megasquirt-18/msm-test-car-needed-73683/
Hopefully that just means more options for us.
My ecu upgrade is now further delayed. Bought another car instead!
It will happen though. The BMW 135i is definitely not a long term car.
davekmoore
Postby davekmoore » Mon Jul 08, 2013 2:05 am
So BARMY starts to go back together soon and I need help from the boffins on here please. Apologies for not starting a new thread and hijacking this one but it seemed better to keep all the similar info in one place for others with SEs.
The car sees a lot of track use and I'm rather less slow than I used to be.
No current plans to change what was already on the car: Mazdaspeed AEM air intake, Cooling Pro intercooler, SP Motorsports 2.5 inch exhaust, Denso 440cc injectors, GFB recirculation valve, BEGi TB inlet, Haltech boost solenoid, Haltech Interceptor (piggyback) ECU, OG 02 Clamp.
The motor will also now be getting a cooling re-route, bigger rad, bigger oil cooler, built and balanced bottom end with a strengthened harmonic balancer and stronger valve springs. The IHI turbo goes back on for now.
There's a faction saying keep the Haltech and get a conservative tune under plenty of load and with heaps of heat sink since this is the only way to avoid detonation with this setup. This may mean a lot of $$$ in dyno time and isn't a complete solution to avoiding detonation without sacrificing power.
The other faction says go Megasquirt for lots of reasons, including its ability to take out timing (and/or reduce boost/add fuel?) when it sees too much heat. This means buying a MS and some dyno time but does mean the maximum power can mostly be had while always avoiding detonation.
In the short term I intend to run the Haltech with the low power 150rwkw map while the engine's bedding in.
After that, I need opinions on keeping the Haltech or getting a MS please, and whether the 440cc injectors are big enough for track use.
Sean
Postby Sean » Mon Jul 08, 2013 2:22 am
Dave,
Only you can decide what you think is right for your situation, we all have opinions and, both sides have benefits and drawbacks.
If it were me, in your situatuation, It'd depend on the haltech model... If it's a late model (or even a recent model) it should have a bunch of features to help protect against problems - some of them may not have been enabled in the current tune. I'd run it standalone and buy a pnp harness (again, assuming it's a late model).
From memory you were/are close to the end of functional size of the injectors too, I'd swap them out for bigger ones prior to any tuning, and maybe even go for a pump upgrade - both are cheap insurance.
davekmoore
Postby davekmoore » Mon Jul 08, 2013 9:22 am
Thanks for your thoughts Sean.
The Haltech may be 8 years old.
Postby 93_Clubman » Mon Jul 08, 2013 12:35 pm
Dave, six years since the Haltech Interceptor was fitted - sounds like it was new when fitted, given local support from the manafacturer was one of the prerequisites: viewtopic.php?f=29&t=25862
kenson
Postby kenson » Thu Sep 12, 2013 8:15 pm
More news/options from DIYAutoTune (Mazda-speed forums):
Got an email back from Matt at DIY. They're about a month away but no pricing yet. Probably a bit more expensive than the other Miata PNP since the MSM PNP is going to use the MS3Pro which looks great but probably overkill for most of us.
http://www.mazda-speed.com/forum2/index.php/topic,28451.15.html
Users browsing this forum: No registered users and 120 guests
