RON NB8A Turbo
Novice1
Re: RON NB8A Turbo
Postby Novice1 » Mon Apr 15, 2013 8:29 pm
Weight reduction will help that old barge get going.
Novice1
TIP
Re: RON NB8A Turbo
Postby TIP » Tue Apr 23, 2013 12:14 am
Removed soft top and some sound deeding should save 24kg and the 7KG boot strip. Mite get a bikini top type thing later out if its not to hard to install.
parts ordered
LOCKWOOD WOVEN MESH STAINLESS FRONT GRILLE
EYE BROWS
JVC DOOR SPEAKER SET
Also going to take headlight apart and clean them up and tint it black.
Novice1
Re: RON NB8A Turbo
Postby Novice1 » Tue Apr 23, 2013 12:35 am
Though i like the grill, I think it would reduce airflow.
Novice1
Re: RON NB8A Turbo
Postby Lokiel » Tue Apr 23, 2013 10:50 am
+1
You seem to want the car to produce even more grunt yet are adding something which restricts airflow?
Any style grille will restrict airflow, no matter how large the holes are.
I added one initially to protect the intercooler from stone damage when DD but removed it once I learned how much they affect airflow - I reckon I can afford a new eBay Cooling-Pro intercooler every few years.
TIP
Re: RON NB8A Turbo
Postby TIP » Tue Apr 23, 2013 12:42 pm
True dam mite not put it on then.
initial D
Re: RON NB8A Turbo
Postby initial D » Tue Apr 23, 2013 12:56 pm
In that case i mite get the Offset Number Plate Bracket thing so its on the plates are on the right hand bottom side .
TIP
Re: RON NB8A Turbo
Postby TIP » Fri May 03, 2013 7:20 pm
Eyelids in
Tinted headlights
Holes filled
Bride Bucket seats
Number plate bracket
JVC 310W speakers fitted
Future mods 6 speed and tinting the tail lights white areas all red
TIP
Re: RON NB8A Turbo
Postby TIP » Tue May 07, 2013 7:39 pm
plastic dips window frame might do some other parts any ideas?
Re: RON NB8A Turbo
Postby Lokiel » Tue May 07, 2013 8:05 pm
Tinted headlights look great.
Not sure about the plasti-dip though since your dark green doesn't really allow enough contrast for it to "work" (JMO).
Re: RON NB8A Turbo
Postby NitroDann » Tue May 07, 2013 8:12 pm
Post a wider shot of the car in the sun, i reckon the plastidipped roof will look good in the sun :)
narita
Re: RON NB8A Turbo
Postby narita » Tue May 07, 2013 8:49 pm
I have never been a fan of eyelids.
These however make me smile.
WINTON PB - 1:57.4000
TIP
Re: RON NB8A Turbo
Postby TIP » Thu May 16, 2013 8:53 pm
My CB HT with clear coat love the CB look not painting it.
Total weight reduction from 1105 to 1039 kerb weight
TIP
Re: RON NB8A Turbo
Postby TIP » Thu May 16, 2013 9:06 pm
Novice1
Re: RON NB8A Turbo
Postby Novice1 » Thu May 16, 2013 9:38 pm
Looks great. Thats a great weight reduction, should get the oldbarge moving a bit better.
Novice1
TIP
Re: RON NB8A Turbo
Postby TIP » Thu May 16, 2013 9:43 pm
oh yes it does and more tail happy :P
Users browsing this forum: No registered users and 214 guests
