Cold air intake problem
BarryB
Postby BarryB » Tue Apr 16, 2013 6:10 pm
Morning all
I have fitted a K&N cold air intake to my NB8B and I now occassionally have a soft "popping"sound when the engine is cold and idling or being started when warn. It is a sound similar to a car spitting back though the carby. Mazda have checked the car over changed the plugs and reset the engine management system but without rectifying the problem. There is no loss of power and it does not happen on accelaration.
Does anybody have any suggestions?
BarryB
Re: Cold air intake problem
Postby 93_Clubman » Wed Apr 17, 2013 10:36 am
BarryB
Postby BarryB » Wed Apr 17, 2013 12:02 pm
Thanks Clubman. All of the info sounds like it applies to mine. It is a "soft" sound and not as sharp as a backfire. I'll try turning the wheel to the left or right and see what happens. As I said in my original post it is not constant so it is not like a faulty plug with a constant miss.
Thanks for your advice
Barry B
Postby manga_blue » Wed Apr 17, 2013 2:25 pm
The CAI would make any popping that was already there much more audible. So it's possible that you've had it for years without it being a problem.
The links that 93_clubman posted were applicable to NA series cars which had quite different idle and timing control systems from your NB8B's. In general, backfiring into the intake manifold can be caused by lean fuel mixture or ignition/timing problems or valve timing problems.
I can't give a direct answer, just a brain dump of hypotheticals. Don't read any further if you don't want to hear about a whole raft of potential issues.
Assuming you're running a standard ECU and engine sensors then a lean mixture problem could in theory be:
- a weak injector (failing to deliver a charge occasionally or else consistently under-delivering)
- a faulty engine coolant temp sensor, so the ECU thinks the engine is warmer than it really is and doesn't request a large enough charge for cold running
- a faulty intake air temp sensor, so the ECU thinks the air is warmer than it really is and doesn't request a large enough charge for the larger mass of cold air
NB8B timing is fully electronically managed. An ignition/timing problem may be due to:
- faulty/wrong spark plugs
- poor spark plug earthing (did you put a coating of non-conductive grease on the spark plug threads?)
- faulty plug leads
- faulty ignition coilpack
- faulty cam angle or crank angle sensors
Valve timing problems can also cause idle misses. I suspect that you don't have strong enough symptoms of the timing belt being a tooth out. VVT may be an issue though. Roughly speaking the VVT in an NB8B works by giving the inlet valves full advance from idle to about 3500rpm, then full retard from 3500 to 5500 then full advance again above that. Retarded ignition at idle could cause some popping. Does anyone know if it's possible that a sticking VVT actuator causes partial/full retard at idle? I recall that miata.net has references to heavier oils or mineral oil deposits causing VVT actuator sticking. What grade oil are you using? Clogged/leaking VVT actuators are usually easily cleaned and re-built.
BarryB
Postby BarryB » Wed Apr 17, 2013 5:31 pm
Thanks NA8 I'll give it some more consideration
Barry B
Postby 93_Clubman » Thu Apr 18, 2013 11:31 am
BarryB wrote:Mazda have checked the car over changed the plugs and reset the engine management system but without rectifying the problem.
Importantly you've had your MX5 checked by a Mazda dealer, so if they are competent in their checks, resetting, & diagnosis then you can have some confidence. However, if you're still concerned perhaps get a second opinion from a MX5 specialist.
jonosx
Postby jonosx » Thu Apr 18, 2013 11:45 am
Try resetting your base idle.
I had a similar thing when i installed my intake and from memory it got better after doing this.
Could also be worth giving your throttlebody and IAC a cleanout as well.
Still notice it everynow and then but not as prominent.
BarryB
Postby BarryB » Thu Apr 18, 2013 1:33 pm
Thanks
I'll give it a try
Barry B
Users browsing this forum: No registered users and 82 guests
