As you can see from the pics, the accelerator pedal has cleanly snapped off the assembly/mounting at the firewall. I can't drive it at all.
I driving back from the Blue Mountains today and could feel it coming loose. After closer inspection back in car port when kneeling down I inadvertently snapped it off the mounting trying to see what was going on down there. I swore pretty loudly when I did that!
Looks like the whole assembly under there is that corroded that it didn't take any effort at all for it snap off! Freakin Scary.
Should you rule out trying some spot welding to attach it back on?, If so is it possible to replace the whole assembly altogether? I can't find the name of the plate/assembly anywhere.
Thanks in advance!
