Megasquirt, CAS, pull up resistors, Megastim, help?!
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, zombie, Andrew, -alex, miata, PUR157
AmmoJammo
Postby AmmoJammo » Sun Apr 14, 2013 12:41 pm
I'm posting this anyway, because typing it out actually solved the problem for me.... I'd attached one of the mod wires in the wrong place :oops:
I've assembled a Megasquirt V3.0, with the MSII daughterboard, following various guides, and modifications. (ignore the missing Q16, its on order ;))
The idea is to run an MX5 cam angle sensor, so I've done the modifications found here to add the pullup resistors:
http://www.diyautotune.com/tech_article ... _miata.htm
The tach signal is assembled like so with the 12volt pull up mod connected to D1 (this isn't meant to be D1, its D5! and the reason it didn't work) (470ohm resistor connected to the 12volts)
The issue is, as per the diagram, the voltages? are they meant to be this low at the output of the optocoupler?
Output from the Megastim looks like this, measured at the "input" of R12:
But then the "output" from R12 looks like this?
Is it meant to be that incredibly low? or is something loading it down?
And finally, the output from the optocoupler:
Which is meant to change between high and low.... I'm not sure how high "high" is, but I'd assume its meant to be higher than 72mv? :|
Any assistance would be fantastic? is there something stupidly obvious that I'm missing here?
Thanks!
AmmoJammo
Re: Megasquirt, CAS, pull up resistors, Megastim, help?!
Postby AmmoJammo » Sun Apr 14, 2013 5:02 pm
I have no idea how to enable the wasted spark/dual ignition output in the version of TunerStudio 2.0.8 I have?!
I've seen multiple screenshots from older versions, and also from MegaTune, but apparently TunerStudio is newer, and better. :cry:
gslender
Postby gslender » Sun Apr 14, 2013 6:02 pm
AmmoJammo wrote:I have no idea how to enable the wasted spark/dual ignition output in the version of TunerStudio 2.0.8 I have?!
Ignition options - choose wasted spark... done.
G
AmmoJammo
Postby AmmoJammo » Sun Apr 14, 2013 6:23 pm
I can't find any menu that has wasted spark in it.
The 2.0.8 version is completely different to any version of TunerStudio I've seen screenshots of.
AmmoJammo
Postby AmmoJammo » Sun Apr 14, 2013 8:04 pm
apparently it was an old/bad version of the firmware...
changed to MS2extra 3.2.4, and now it has the wasted spark settings...
only thing is though, I've built the circuit to trigger one coil using D14, the other using D16... there seems to be no option for this :|
AmmoJammo
Postby AmmoJammo » Sun Apr 14, 2013 9:34 pm
Apparently if you "Set "wasted spark" when 4 cylinder and you will automatically get sparkB on LED16."
But it doesn't work?
D16 does nothing, there's no signal there at all?
Return to “MX5 Technical Guides”
Users browsing this forum: No registered users and 18 guests
