HANS Device - group buy
mazmad
Postby mazmad » Sun Apr 07, 2013 8:42 pm
If anybody is interested, a few of us are looking at the Hans devices.
Hans Device with fittings.
Options are
Hans Sport I $599. 1250 grams
Hans Sport II $749 950 grams
Hans carbon model (forget model name) $1250 and 650- grams
Only difference is weight.
Depending how many participate we will get between $50 and $75 discount, plus they will mount the fittings to your (Hans compatible) helmet. Through Revolution RACEGEAR in Brookvale.
Keen?
Put your hand up.
Re: HANS Device - group buy
Postby Magpie » Sun Apr 07, 2013 8:50 pm
HANS Sport 1 (Med), postage to Brisbane please.
james_hay
Postby james_hay » Mon Apr 08, 2013 7:39 pm
I'm interested. Hans Sport 2 to Brisbane as well...
mazmad
Postby mazmad » Mon Apr 08, 2013 9:35 pm
Ok James.
So confirmed today will be minimum of $50 off either a Hans Sport I or Sport II. Airbag will be $15. Those in Sydney can get the fittings put on their helmet. So Sport I is $550, Sport II is $700.
So to confirm:
1. Craig / mazmad Sport II (Sydney) - medium
2. Magpie Sport I (Brisbane) - medium
3. James_Hay Sport (Brisbane) - medium?
4...?
mazmad
Postby mazmad » Fri Apr 12, 2013 11:00 am
Toppertree I am still going the HANS as I have already tried it on and lined up fitting.
James
If you can pm me your address and confirm the order, I will send all details - model, size, address - to Revolution Racegear Brookvale and then all we each need to do is call them to give them payment. I will send you their ph number.
MattR
Postby MattR » Fri Apr 12, 2013 11:50 am
Just to let you guys know, Demon Tweeks in the UK have the Hans Sport II for $500 delivered. I am just getting a couple more details from them and will then decide wether to go the Hans or necksgen device for myself.
Steampunk
Postby Steampunk » Fri Apr 12, 2013 11:58 am
MattR wrote:Just to let you guys know, Demon Tweeks in the UK have the Hans Sport II for $500 delivered.
That's rather cheap and Demon Tweeks aren't cheap, usually. Leads me to think you can find them even cheaper in the internets...
MattR
Postby MattR » Fri Apr 12, 2013 12:18 pm
That's about the cheapest you will find them on the internets, maybe a couple of dollars cheaper, but not much.
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Fri Apr 12, 2013 12:39 pm
If you need the helmet with posts too, as I do, autosport.com.au has some good deals on the stand21 HANS with Velo helmets.
mazmad
Postby mazmad » Fri Apr 12, 2013 1:26 pm
Hey Matt - that's cheap. $200 cheaper in fact! My concern is fitting to my helmet, need someone to do that for me which is why going with a local supplier. I want to get it fitted right given the importance of this bit of gear (hence why old dunderhead / fumblefingers here is NOT going to do it himself... :D )
Magpie - James - you should get them from there seeing as you are fitting them yourself.
:frown: Sucks doesn't it for the local provider, provide the service and demo's....but money talks as always!
greenMachine
Postby greenMachine » Fri Apr 12, 2013 2:06 pm
mazmad wrote:... My concern is fitting to my helmet, need someone to do that for me which is why going with a local supplier. I want to get it fitted right given the importance of this bit of gear (hence why old dunderhead / fumblefingers here is NOT going to do it himself... :D )
I did mine. The helmet holes are already in the helmet, and if you can tell the difference between a nut and a bolt, you should be ok - the instructions (with mine - a Bell from Pegasus in the US) were straightforward.
:mrgreen:
mazmad
Postby mazmad » Fri Apr 12, 2013 2:22 pm
You may be overestimating my abilities. :shock: But thanks will give it a lash then.
mazmad
Postby mazmad » Fri Apr 12, 2013 7:02 pm
So demontweeks has them including shipping to Australia as Matt said for $500. There is a small saving on freight for the second or third item. But then it has to be shipped within Australia to whomever orders them.
Suggest you boys in Brisbane pair up and order them if you want.
MattR
Postby MattR » Fri Apr 12, 2013 11:13 pm
You will also need to get posts at a rough cost of $50 so will be $550 all up to your door with a 5-7 day turn around according to the email I got back. I will be calling the sales rep who answered my email and ordering tonight.
They can also size it based on your shirt collar size, and since I played rugby in the tight 5 I will no doubt be vetting the large one to fit my neck and chins :)
mazmad
Postby mazmad » Sat Apr 13, 2013 7:15 am
As I played rugby in the backs I only need a medium. :D Thanks for tip re posts I couldn't find them on the website but figured I could get them locally.
Edit....scrap that, got them, Scroth posts. So makes it $550 vs $700 with free fitting. Hmmm.
Return to “MX5 Motor Sport”
Users browsing this forum: Bing [Bot] and 3 guests
