Adjusting rear swaybar
sticky nicky
Vehicle: NA6 - Turbo
Postby sticky nicky » Fri Apr 12, 2013 6:59 pm
I am wanting to adjust my rear swaybar to soften it, its currently on the middle setting. I cant see how I can move the adjustable arm that goes up to the swaybay as it pivets the wrong way on the lower end for the front to back movement I need where it connects to the swaybar.
Its a whiteline swaybar and should be adjustable as it has the holes there.
Also when the two bolts are taken out of the swaybar, should I be able to rotate it in the bushes as it does want to move, maybe I need new bushes?
See pics below
Would appreciate some advice,
thanks Nicky
Re: Adjusting rear swaybar
Postby NitroDann » Fri Apr 12, 2013 7:01 pm
Just push harder, this is the only solution with stock sway links.
Postby manga_blue » Fri Apr 12, 2013 8:15 pm
Sometimes the only way you can do it is by bending the end links. I use a good vice and a small sledge hammer. The links themselves are tough as.
project.r.racing
Postby project.r.racing » Fri Apr 12, 2013 9:17 pm
loosen the other bolt on the link.
sticky nicky
Postby sticky nicky » Sat Apr 13, 2013 12:20 pm
Ok, thanks for your help guys :D
evil_weevil
Postby evil_weevil » Wed Apr 17, 2013 9:32 pm
Sorry to hi-jack thread, but I had an issue ages ago with my front whiteline sway bar, nothing I could do would get it into the hardest setting, only the middle one.
would this help?
http://www.mx5mania.com.au/product659.htm
viewtopic.php?f=73&t=62834
project.r.racing
Postby project.r.racing » Thu Apr 18, 2013 2:04 pm
yes as the rose joints allow more flexability with angles.
evil_weevil
Postby evil_weevil » Fri Apr 19, 2013 3:46 pm
ah fantastic!
now, wheres the cheapest place to buy from hah
Users browsing this forum: No registered users and 349 guests
