Disappopinted $2000 spend
lizard
Re: Disappopinted $2000 spend
Postby lizard » Wed Apr 10, 2013 11:29 am
mexiegirl wrote:
lizard wrote:Just putting it out there twin Dellorto 32mm choked to 30mm would scream
EEEEUUUUUWW yucky, no thanks, I know it's great for horseys but all that tuning every second day
What do you mean tuning every second day?
project.r.racing
Postby project.r.racing » Wed Apr 10, 2013 12:43 pm
NitroDann wrote:He is a poor tuner.
Get a new one.
:BROADY:
rascal
Postby rascal » Wed Apr 10, 2013 2:09 pm
You know. Tune it first today when its 35degrees. Then have to retune it tomorrow cos now its 15degrees and all the mixtures are out, then retune again the next day cos its back to 35 degrees and they are out again.
or
tune it to worst case scenario so you never have to retune again, but put up with less than perfect running for 99% of the time..
I agree with mexiegirl. EEEEUUUUWWWW.
mexiegirl
Postby mexiegirl » Wed Apr 10, 2013 5:33 pm
LOL hehehe thanks Rascal
Postby manga_blue » Wed Apr 10, 2013 6:26 pm
rascal wrote:You know. Tune it first today when its 35degrees. Then have to retune it tomorrow cos now its 15degrees and all the mixtures are out, then retune again the next day cos its back to 35 degrees and they are out again.
Luuuxury! I had these Solexes on a Fiat. The tune changed when the sun hit it driving out of the workshop.
Great noise at 9,000rpm though!
sailaholic
Postby sailaholic » Wed Apr 10, 2013 7:42 pm
Get a new one.
And his dyno is pretty optimistic I would say.
FYI my engine is 1.8 with the biggest regrinds warren could fit (bigger then yours from memory) and ported, 1mm oversize inlet and exhaust valves and a shave and variable cam gears. Also runs itbs with an adaptronic and made 131 hp at the wheels.
A built of ford bda cosworth motor with itbs made 153ish hp on the same dyno and other full bottom end rebuilt ect mx5s made about 140.
Tuner said that in the search for power he put heaps of ignition advance in and never got any pinging just power loss.
My car also idle quite well (if a little low sometimes) no bunny hops ect and it was like that before the tune (is base map from adaptronic)
I'm not hating, just supplying you some alternative views/ info.
wozzah1975
Postby wozzah1975 » Wed Apr 10, 2013 8:03 pm
or
Properly tuned and set up Webers or Dellortos aren't anywhere near as bad as you're stating even for drivability and tuning, and power wise they crap all over the OE Mazda manifold and ECU arrangement, fullstop. The biggest issue with them is finding someone who knows what they are doing with them, as there are plenty that think they do and haven't got a clue.
20 years ago Webers or Dellortos would have been a good option, but in this day and age though, it is almost as economical to fit throttle bodies and be done with it.
Woz
wozzah1975
Postby wozzah1975 » Wed Apr 10, 2013 8:05 pm
Get a new one.
obvious pinging and jerking, it should never have left the workshop
Woz
fcruz3r
Postby fcruz3r » Thu Apr 11, 2013 3:13 am
What sort if ping counts per ms are u talking about. If less than 3 and random then prolly nothing to worry. But if its audible ping n jerking, then its badly tuned. Take it to another tuner who knows the ecu n tuning software.
Final dyno figures means eff all if u dont hv the base dyno figures. These can be fudged
little decks
Postby little decks » Thu Apr 11, 2013 1:49 pm
fcruz3r wrote:What sort if ping counts per ms are u talking about. If less than 3 and random then prolly nothing to worry. But if its audible ping n jerking, then its badly tuned. Take it to another tuner who knows the ecu n tuning software.
:BROADY:
Power curves matter much more than your final number... if its pinging and jerking your going to have a curve that resembles the outline of mt rushmore.
mexiegirl
Postby mexiegirl » Thu Apr 11, 2013 7:55 pm
As a daily driver to work ect.. carburetors are just done for me. I have had too many roadside carby o/hauls and flooding from them. For the track definately...
Aparently the TPS can be fine tuned to not bunny hop, and the tune guy has agreed to bring back the timing if needed.
I tend to agree with Woz the most as it shouldn't have left the workshop pinging and bunny hoping (I forgot to add hunting up and down 300 rpm). pinging in itself ruins the engine and performance, thats a no bainer
mexiegirl
Postby mexiegirl » Thu Apr 11, 2013 8:07 pm
It's quite audible and i'd say it's badly tuned, the tuner sells and fits adaptronic (thats all I can say)
:BROADY:
kinda true best power was at 7,000 rpm
wozzah1975
Postby wozzah1975 » Thu Apr 11, 2013 8:52 pm
mexiegirl wrote:As a daily driver to work ect.. carburetors are just done for me. I have had too many roadside carby o/hauls and flooding from them. For the track definately...
At 10:1 you shouldn't even have a hint of pinging on 98, so I'd be concerned why you have. If the TPS is calibrated correctly to begin with then it shouldn't need adjusting. Once you set, you forget.
Woz
Sean
Postby Sean » Sun May 12, 2013 3:19 am
Curious as to why you added the wideband? Is it running autotune with the Adaptronic or just for you to watch?
How do the AFRs look around pinging?
I'm not going to try and suggest solutions other than a retune with someone who knows what they are doing.
I'll also suggest that no matter what the tuner wants to tell you about their abilities, if it left pinging and with messed up idle there is clearly some shortcomings in the tune. I've seen a few average tunes from someone claiming to be a specialist that did almost exactly what you are describing...
mexiegirl
Postby mexiegirl » Wed May 29, 2013 7:12 pm
Hi there Sean
Sorry for late delay
see below thread for my frustrated but happy with Adaptronic response
viewtopic.php?f=55&t=58316
I was told to buy the wide band from MX5 mania so he could tune it easier (tune is used quite loosely)
I totally agree that it shouldn't drive away pinging for many reasons, MX5 mania should know how to tune my NA8 than anybody else in Sydney, i'm so pissed to the damage they have done to my car (clutch, d/line ect..).
