Boyracers Enduro/Rental eBay Special.
Boyracer
MX-5 Encyclopedia
Re: Boyracers Enduro/Rental eBay Special.
Postby Boyracer » Thu Apr 04, 2013 2:43 pm
As the little guy said there are brackets welded to the cage and the stock hard top bolts on, Streat Neat did a great job with this one so the brackets for the carbon fibre top slip over the cage and it bolts where the normal brackets would be obove the windscreen so I can run either type of hard top.
I actually hate running the hard top, it's there in case I ever go to a track like Phillip island where the hard top actually makes a big difference.
mitch_f1
Postby mitch_f1 » Sun Apr 07, 2013 2:29 pm
If you could, I would be really curious to see some pictures of how you've done it (my minds eye is struggling)
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Mon Apr 08, 2013 6:00 pm
Fast engine is in, going to MX5 Mania tomorrow for tuning, if all goes well will be at Wakefield on Sunday.Image
toppertee
Postby toppertee » Mon Apr 08, 2013 10:18 pm
What's the build specs on the fast motor?
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Tue Apr 09, 2013 5:55 pm
Engine has Supertech forged pistons, big oversize, Carillo rods, big cams, porting work on the head, somewhere around 120-130 rwkw.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Tue Apr 09, 2013 6:55 pm
Here you can see the bracket welded to the roll cage to mount stock hard top and the alloy bracket on the C/F hard top that just bolts the the stock hard top mount point above the windscreen.
mazmad
Postby mazmad » Wed Apr 10, 2013 8:18 am
Boyracer wrote:somewhere around 120-130 rwkw.
:shock:
Drool...............
mitch_f1
Postby mitch_f1 » Thu Apr 11, 2013 5:18 pm
Thanks very much :)
Postby NitroDann » Thu Apr 11, 2013 5:49 pm
:shock:
Lots could have this except unlike lou 98% lack the balls to put big enough cams in.
Super well done Lou. :P
mazmad
Postby mazmad » Thu Apr 11, 2013 6:28 pm
NitroDann wrote:Lots could have this except unlike lou 98% lack the balls to put big enough cams
Cash may have something to do with it.
Anyway I thought you were a 'chuck in a $3k turbo' guy, not adding big cams, headwork?
Postby NitroDann » Thu Apr 11, 2013 6:46 pm
Protip: Small cams and big cams cost the same amount.
I am the 3k turbo guy but if you do n/a why spend 3k and get 10hp when you can do as lou has use bigger cams and make 40hp?
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Apr 11, 2013 8:50 pm
I did the turbo thing, went back to NA in the NA so I could do the Prod.Sports stuff, have not regretted it one bit, you go to race meeting, never have to open the bonnet and it still goes fast, and sounds fat....doesn't matter how well the turbo car is built there are always problems.
toppertee
Postby toppertee » Thu Apr 11, 2013 11:10 pm
Boyracer wrote:I did the turbo thing, went back to NA in the NA so I could do the Prod.Sports stuff, have not regretted it one bit, you go to race meeting, never have to open the bonnet and it still goes fast, and sounds fat....doesn't matter how well the turbo car is built there are always problems.
I'm about to start a turbo build. Now you have me worried.
How bad? Is a turbo car to track? I'm aiming for 200hp low boost.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sat Apr 13, 2013 9:29 am
Running a MX5 anything above about 150rwkw on the track and everything gets really stressed, we have all talked about it before, starts with front hubs, gearboxes, rear CV joints, diffs, rear hubs, overheating, exhaust cracking, turbo stud breaking...all of the Turbo MX5 race cars have had these problems...so if you wants to run a good turbo car you can expect to have to deal with some of these, with my car running at about 130ish rwkw I have never had any of these things fail....I did spend quite a bit of money on the engine but I did it right in the first place and it has been great, a lot of thanks go to David and MX5mania for their help with the engine.
mazmad
Postby mazmad » Sat Apr 13, 2013 6:14 pm
Not being a spanner guy (clean windscreen, check oil, no problem....) that is exactly why I also want to go the n.a. route. Sound great, hopefully simple to run...
Users browsing this forum: No registered users and 303 guests
