Fuel injector size, duty cycle and the meaning of life...
plohl
Postby plohl » Thu Apr 04, 2013 6:34 pm
Hi guys,
I have just picked up a set of itb's for my 1.8L NA mx5/miata/roadster. It is supposedly making 130rwhp with tighe 805C cams and I am using a haltech e6x and batch injection.
As far as I know I am using the stock injectors for the BP engine which are 254cc/min (ref: http://miataturbo.wikidot.com/fuel-injectors). Using the reference I calculated that the injectors would be good for about 155 crank shaft HP with a BSFC = 0.5 and 80% duty cycle.
Code: Select all
Math
cshp = (254cc/min x 4 x 0.8)/(10.5 x 0.5)
     = 154.81 cshp
So this tells me I am almost at the limit of the injectors.
I copied the injection pulse width (IPW) values from the fuel map and used excel to determine the duty cycles across the map. I used this the method outlined here to calculate the duty cycle http://www.hywell.org/plhelp/injdutycycle.html. My max IPW at 100% TPS, 7500RPM was 7.131, so the duty cycle was calculated to be 47.5%.
I had to think about this at first as i was pretty confused as to why it is so small, but then it dawned on me that the batch firing influences the IPW. I have had a bit of a search, but haven't found anything concrete. Is is safe to assume that the injection duty cycle is double? So the ducty cycle would be 95%!!!!!! As the injector is fired twice per engine cycle (720* crank rotation).
Or is it better to assume that only a percentage of the fuel injected during the other cycle is used?
Either way, i am not expecting huge gains with the ITB's, but is it safe to say I'll need bigger injectors? Just confirming this before I lash out and buy some.
plohl
gslender
Re: Fuel injector size, duty cycle and the meaning of life..
Postby gslender » Thu Apr 04, 2013 6:56 pm
Nah, all fuel is used, and is why batch fire with large injectors won't idle... You can't get the pw small enough as they are all adding fuel. At WOT, batch and sequential makes little difference, obviously due to the limited time between squirts.
As for the calcs, doesn't the ecu tell you the duty cycle?
G
plohl
Postby plohl » Thu Apr 04, 2013 7:03 pm
gslender wrote:Nah, all fuel is used, and is why batch fire with large injectors won't idle... You can't get the pw small enough as they are all adding fuel. At WOT, batch and sequential makes little difference, obviously due to the limited time between squirts.
G
Cool. It makes sense.
Stupid batch fire! Means i cant get too big an Injector. Hmmm...
I think it does but i don't have the car at the moment.
Before you say it, i know, i should get a new Ecu :p
plohl
sailaholic
Postby sailaholic » Thu Apr 04, 2013 7:03 pm
E6x is when haltec first moved from dos to windows. So no very basic and no duty cycle info we have found in the menus
Steampunk
Postby Steampunk » Thu Apr 04, 2013 8:01 pm
plohl
Postby plohl » Thu Apr 04, 2013 8:24 pm
seen that one dude - same equations i used.
I could get an adjustable fpr but I can see that adding up quickly.
plohl
Postby NitroDann » Thu Apr 04, 2013 8:32 pm
Its fine, look what are your AFRs?
Steampunk
Postby Steampunk » Thu Apr 04, 2013 8:41 pm
So the haltech is configured correctly for the 254cc? I would just use them until you definitely feel you've maxed them out because if you can't enter the new injectors' latency/lag/dwell time into the software then your fuel map will be out of wack.
plohl
Postby plohl » Thu Apr 04, 2013 8:51 pm
NitroDann wrote:Its fine, look what are your AFRs?
Will have to look at some logs, but from memory they're about 13.5-12 wot.
I thought about just seeing how they go but i essentially have to have everything done one weekend, so don't want to find out they're too small
plohl
Postby NitroDann » Thu Apr 04, 2013 9:08 pm
13.5 is too lean, and 12-13.5 isnt a very steady afr across WOT.
If the injectors can hold 12:1 or lower then their duty is fine.
plohl
Postby plohl » Thu Apr 04, 2013 9:58 pm
looked at some of my logs - WOT afr ~12.5-12.
How can you be sure/justify they'll be fine when everything else is point towards them being just too small?
plohl
Postby NitroDann » Thu Apr 04, 2013 10:09 pm
because they flow enough to make over 160hp at 12.5:1 and you are making 130.
Postby NitroDann » Thu Apr 04, 2013 10:13 pm
They are getting close to the limits however, if it stresses you contact works engineering for a FPR, they are very well priced and small and sexy as hell. Ive had personal experience with the 500hp one and it was great. Anodised black too so pretty low key.
plohl
Postby plohl » Thu Apr 04, 2013 11:55 pm
160 rwhp or at the fly? How do you getting that?
I'll look into some options, was hoping not to touch the fpr as it'll be a catalyst for me to spend more money.
plohl
Postby NitroDann » Thu Apr 04, 2013 11:58 pm
Just get some injectors from soemthing bigger.
flywheel HP, standard calcs.
Users browsing this forum: No registered users and 48 guests
