Headlights won't go down - need LA12 relay?
Earlybird
Postby Earlybird » Thu Mar 28, 2013 8:44 pm
My headlights won't retract when I turn them off. Using the headlight manual over ride button below the hazard lights switch does nothing either.
From what I've read so far, this is a pretty common problem and all fingers point to a dodgy headlight retractor relay.
I have located the relay on my NA (in engine bay for my model) and it is a Imasen LA12. Can anyone tell me where I might be able to pick one of these up from in western Sydney (I'm in Penrith area)?
koop21
Re: Headlights won't go down - need LA12 relay?
Postby koop21 » Thu Mar 28, 2013 8:57 pm
not certain but Jaycar has almost everything relating to electronic stuff so best to check them out.
aka_juffa
Postby aka_juffa » Fri Mar 29, 2013 7:29 pm
G'day/
The problem, as you have described, can also be caused by the connection behind the manual override button being loose, or not being connected at all. It is much simpler/quicker fix than finding a replacement relay.
You have to remove the tombstone to get to the back of the switch. In fact, it is usually removing the tomb stone and forgetting to reconnect the plug on the back when refitting the tombstone that causes this problem. Don't ask how many times I have done this :oops:
J.
Postby manga_blue » Fri Mar 29, 2013 8:13 pm
That's what happened when the LA12 went in our Astina.
Earlybird
Postby Earlybird » Fri Mar 29, 2013 8:21 pm
Ironically, I was going to ask if anyone knows an Astina owner who may have a spare relay as they were cursed with same problem.
I've also fallen victim to not having the wiring connected to the tombstone switch but know this is not the case here as my hazard lights work fine.
Jaycar doesn't seem to have anything similar on their online site but a quick search on Ebay shows some available....all the way from America. Am still crossing my fingers that I might be able to find one locally.
Postby manga_blue » Fri Mar 29, 2013 9:11 pm
I got a whole set of relays once by browsing for part-outs on the Astina forum.
http://www.astinagt.com/forums/index.php
Most of the BG Astina ones interchange. The LA12 was hard to find: it was in the passenger footwell, high up to the left of the glovebox.
myredmx5
Postby myredmx5 » Fri Mar 29, 2013 10:35 pm
Email sent
Earlybird
Postby Earlybird » Sat Mar 30, 2013 3:06 pm
manga_blue wrote:I got a whole set of relays once by browsing for part-outs on the Astina forum.
I've just spent most of the morning scabbing around in local wreckers and every Astina had no LA12 in passenger footwell (behind plastic trim). They all looked like this and are not compatible with my plug. Bit of a bugger as they only wanted $10 for a relay
Postby manga_blue » Sat Mar 30, 2013 4:12 pm
Yeah, really sorry man for leading you on a wild goose chase. I've got fuel inj and cooling relays from an Astina in my NA but apparently not the retractor. I thought I'd fixed that with an Astina one as well. RELAY-RETRA is only the retractor relay in my Astina.
Earlybird
Postby Earlybird » Sat Mar 30, 2013 4:44 pm
it's ok, picked a few other bits up for my step daughters cars while I was there so the visit wasn't fruitless.
Users browsing this forum: Google [Bot] and 4 guests
