Electric boot release
- dbr
- Vehicle: NB8A - Turbo
Cam anybody tell me which model MX5's came with electric boot releases?
Re: Electric boot release
My guess would be the NC.
NA6 had no internal release
NA8 unsure
NB8A has the normal wire/level type
NB8B I think has the same as NB8A
NA8 unsure
- Smacca
My NB SE had remote electronic boot access (unsure if that's standard) and also the wired lever.
My NA8 has the wire lever only. But I plan to fix that with a motor kit soon.
Smacca | 1993 NA8 Clubman
- Jeo
Imported NA6's had an internal release.
- shuey
NB8B has an electronic boot release through the key fob
2001 Sunlight Silver NB8B - SOLD - 23/6/16
- dbr
thankyou
At least some ADM NA6 had the internal release lever.
Jeo wrote:Imported NA6's had an internal release.
Are you sure? Earlier NA6 had no boot release, i think its the later na6 got internal release.
- Jeo
Could have just been a later NA6 thing. Both the imports I've had significant dealings with were '93 models so you could be right.
I had a SNC na6 without and now long nose with the internal release.
I replaced a broken boot lock with only an electric release but then got a flat battery and had to jump start from the starter motor.
Years ago I did a write up on how to use one of these:
http://www.jaycar.com.au/productView.asp?ID=LR8834
Still cant find the photos.
The 3 button early NB Mazda alarms can be modified to turn the 3rd button into a boot/trunk release.
- KevGoat
I used one of the Jaycar kits to fit an electric boot release with remote central locking on my NA6. Now gives me remote unlocking on doors and boot. It wasn't a particularly difficult job. I also fitted a switch in the center console wired through to the boot release so that I can open the boot from inside the car without the remote. Amazing how handy that switch has become!
Hi, do you have a write up of how to install this kit? also which exact kit did you buy from JayCar and do you know if it is still for sale? thanks Champ
