Electric boot release
dbr
Vehicle: NB8A - Turbo
Postby dbr » Mon Mar 25, 2013 12:39 pm
Cam anybody tell me which model MX5's came with electric boot releases?
Re: Electric boot release
Postby hks_kansei » Mon Mar 25, 2013 12:58 pm
My guess would be the NC.
NA6 had no internal release
NA8 unsure
NB8A has the normal wire/level type
NB8B I think has the same as NB8A
Smacca
Postby Smacca » Mon Mar 25, 2013 1:52 pm
My NB SE had remote electronic boot access (unsure if that's standard) and also the wired lever.
My NA8 has the wire lever only. But I plan to fix that with a motor kit soon.
Postby Jeo » Mon Mar 25, 2013 2:00 pm
Imported NA6's had an internal release.
shuey
Postby shuey » Mon Mar 25, 2013 2:39 pm
NB8B has an electronic boot release through the key fob
dbr
Postby dbr » Tue Mar 26, 2013 7:58 am
thankyou
Postby 93_Clubman » Wed Mar 27, 2013 10:21 am
At least some ADM NA6 had the internal release lever.
koop21
Postby koop21 » Wed Mar 27, 2013 1:20 pm
Jeo wrote:Imported NA6's had an internal release.
Are you sure? Earlier NA6 had no boot release, i think its the later na6 got internal release.
Postby Jeo » Wed Mar 27, 2013 1:37 pm
Could have just been a later NA6 thing. Both the imports I've had significant dealings with were '93 models so you could be right.
Postby NitroDann » Wed Mar 27, 2013 1:49 pm
I had a SNC na6 without and now long nose with the internal release.
I replaced a broken boot lock with only an electric release but then got a flat battery and had to jump start from the starter motor.
Postby Okibi » Thu Mar 28, 2013 2:12 am
Years ago I did a write up on how to use one of these:
http://www.jaycar.com.au/productView.asp?ID=LR8834
Still cant find the photos.
The 3 button early NB Mazda alarms can be modified to turn the 3rd button into a boot/trunk release.
Postby Okibi » Thu Mar 28, 2013 2:16 am
This is how it was done in my NA6 (I did it differently in my NB)
Postby KevGoat » Thu Mar 28, 2013 9:12 am
I used one of the Jaycar kits to fit an electric boot release with remote central locking on my NA6. Now gives me remote unlocking on doors and boot. It wasn't a particularly difficult job. I also fitted a switch in the center console wired through to the boot release so that I can open the boot from inside the car without the remote. Amazing how handy that switch has become!
khlmx5
Postby khlmx5 » Thu Jul 24, 2014 8:41 pm
Hi, do you have a write up of how to install this kit? also which exact kit did you buy from JayCar and do you know if it is still for sale? thanks Champ
Postby Okibi » Fri Jul 25, 2014 12:49 am
Users browsing this forum: No registered users and 134 guests
