Low voltage relay problem
Postby Magpie » Sat Mar 23, 2013 4:05 pm
Can somebody help with the following problem?
I need to switch on a 12 volt light when voltage on the control circuit drops to zero. The control circuit is 1.7 volt and 3.8 ma when OK, when there is a fault it drops to zero.
I assume that a relay can be used but I can not find one that will stay open at such a low voltage/amps.
Re: Low voltage relay problem
Postby manga_blue » Sat Mar 23, 2013 7:18 pm
Postby Magpie » Sat Mar 23, 2013 8:18 pm
Thanks.
Users browsing this forum: No registered users and 231 guests
