Difference between JDM NC engine and the Australian delivery
- Learner Driver
This may have been asked before
What's the difference? Why does their's pull out 125kw and ours 118kw?
Re: Difference between JDM NC engine and the Australian deli
Their high-oc fuel is 100 not 98 from memory.
Mazda de rates for our fuel. The new sp20 sky active 3 has lower compression to be run on 91 instead of 95.
- Zcootz
So am I wasting my $$$ running premium into NB8a ?
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Murray Walker
- Vehicle: Non MX-5
use higher octane fuel, adjust timing, get same result as JDM.
- Learner Driver
project.r.racing wrote:use higher octane fuel, adjust timing, get same result as JDM.
what's timing?
... Not sure if serious ?
- Zcootz
I hope not....
Murray Walker
Murray Walker
as_1 wrote:project.r.racing wrote:use higher octane fuel, adjust timing, get same result as JDM.
what's timing?
Timing is what you worry about before you get married.
- Steampunk
- Learner Driver
i'm being serious lol
- KevGoat
Thought one couldn't change the timing on NB's onward due to ECU/knock sensor and then VVT on the later models? ....
You can change anything with man performance parts.
as_1 wrote:i'm being serious lol
Rather than anyone explaining it, just google ignition timing, but its pretty much about changing the point in the stroke at which your spark ignites your fuel
KevGoat wrote:project.r.racing wrote:use higher octane fuel, adjust timing, get same result as JDM.
For NB use one of these: http://forum.miata.net/vb/showthread.php?p=5925040
