Difference between JDM NC engine and the Australian delivery
as_1
Postby as_1 » Wed Mar 20, 2013 1:02 pm
This may have been asked before
What's the difference? Why does their's pull out 125kw and ours 118kw?
vrmmmpshhh
Re: Difference between JDM NC engine and the Australian deli
Postby vrmmmpshhh » Wed Mar 20, 2013 1:55 pm
Their high-oc fuel is 100 not 98 from memory.
sailaholic
Postby sailaholic » Wed Mar 20, 2013 3:44 pm
Mazda de rates for our fuel. The new sp20 sky active 3 has lower compression to be run on 91 instead of 95.
Zcootz
Postby Zcootz » Wed Mar 20, 2013 7:14 pm
So am I wasting my $$$ running premium into NB8a ?
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
project.r.racing
Postby project.r.racing » Wed Mar 20, 2013 7:25 pm
use higher octane fuel, adjust timing, get same result as JDM.
as_1
Postby as_1 » Fri Mar 22, 2013 9:24 am
project.r.racing wrote:use higher octane fuel, adjust timing, get same result as JDM.
what's timing?
emily_mx5
Postby emily_mx5 » Fri Mar 22, 2013 3:23 pm
... Not sure if serious ?
Zcootz
Postby Zcootz » Fri Mar 22, 2013 6:36 pm
I hope not....
Murray Walker
Apu
Postby Apu » Fri Mar 22, 2013 6:53 pm
what's timing?
Timing is what you worry about before you get married.
Steampunk
Postby Steampunk » Fri Mar 22, 2013 8:22 pm
as_1 wrote:what's timing?
it's 8:22pm
as_1
Postby as_1 » Fri Mar 22, 2013 8:30 pm
i'm being serious lol :oops:
Postby KevGoat » Fri Mar 22, 2013 9:19 pm
Thought one couldn't change the timing on NB's onward due to ECU/knock sensor and then VVT on the later models? ....
Postby NitroDann » Fri Mar 22, 2013 9:24 pm
You can change anything with man performance parts.
little decks
Postby little decks » Sat Mar 23, 2013 11:42 am
as_1 wrote:i'm being serious lol :oops:
Rather than anyone explaining it, just google ignition timing, but its pretty much about changing the point in the stroke at which your spark ignites your fuel
Postby 93_Clubman » Sat Mar 23, 2013 11:58 am
For NB use one of these: http://forum.miata.net/vb/showthread.php?p=5925040
Users browsing this forum: No registered users and 64 guests
