ASI Radiator
- superfluous2
Re: ASI Radiator
Fitted the 52mm one up to my NB with minimal issues.
Not much clearance from the A/C lines, but a bit of wiggling got it in there. 500 km and no leaks so far.
Pretty happy
Pretty happy
NB8A - Winton [1:49.2] Wakefield [1:16.8]
- Vehicle: NB Roadster
Re: ASI Radiator
Sorry to bring back a thread but did anyone with asi's ground their rads?
WINTON PB - 1:57.4000
Re: ASI Radiator
narita wrote:Sorry to bring back a thread but did anyone with asi's ground their rads?
For what purpose?
Re: ASI Radiator
Supposed to prevent corrosion and scale build up through some kind of voodoo electrolysis. Same for fitting a sacrificial anode.
Mine is not grounded and does not have an anode and appears to be okay.
Re: ASI Radiator
I didn't ground mine and it is fine too. No problems so far.
- de Bounce
Re: ASI Radiator
Mine is coming up on 12 months old, no corrosion to be seen inside or out.
Re: ASI Radiator
Anodes won't work effectively inside a rad. It's just voodoo by people with an incomplete understanding of how corrosion works.
Neither should grounding.
Corrosion requires an common electrolyte and 2 materials at different electrochemical potentials and a conducting link (which can be the materials themselves.
Grounding the rad to to a chassis does nothing for the corrosion cell as the chassis isn't in the electrolyte (coolant). The rd is probably already grounded to the chassis through the mounting bolt anyway.
Re: ASI Radiator
could those here with asi's let me know if asi was engraved on the top tank?
Re: ASI Radiator
you would not expect any probs after 1 year- ie it proves nothing. A standard rad will last at least 10 years . I reckon Sailholic knows his stuff on this subject and voodoo is commonly practised in the burbs
- Zcootz
Re: ASI Radiator
From my limited understanding of electrolysis I would have thought that this idea of grounding would only accelerate any corrosion by helping complete the circuit whereas non grounding breaks the loop.
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Murray Walker
Re: ASI Radiator
Zcootz wrote:From my limited understanding of electrolysis I would have thought that this idea of grounding would only accelerate any corrosion by helping complete the circuit whereas non grounding breaks the loop.
True.....IF you park your car in the swimming pool each night.
The electrolyte needed for the corrosion to occur is on the inside not the outside.
- Zcootz
Re: ASI Radiator
Not sure about that, I know we're getting a bit ot but if you've got a couple of electrodes (manifold and radiator ) connected electrically with the coolant as an electrolyte and grounded doesn't the potential for electrolysis occur ? I would have thought so because the electrical connections between the two isn't going to be perfect and there would be some difference? I think I'm overthinkjng this.... Lol......
Either way I don't think I would ground a radiator either.
Murray Walker
Murray Walker
- Vehicle: ND - 2
Re: ASI Radiator
Hi.
The fellow who supplies us with alloy radiators mentioned in passing many years ago the problems are caused by electric leaks into the water from an external source and any radiator shop can test the water for this problem. He has never suggested to us to use earths, anodes or any such things. Just put it in admire and polish and watch your temp gauge needle in the same old spot.
- Pamex
Re: ASI Radiator
You can test for electrolysis by using a multimetre in the coolant. Have a google. I'd put some links up, but dinner is calling!
Re: ASI Radiator
Zcootz wrote:Not sure about that, I know we're getting a bit ot but if you've got a couple of electrodes (manifold and radiator ) connected electrically with the coolant as an electrolyte and grounded doesn't the potential for electrolysis occur ? I would have thought so because the electrical connections between the two isn't going to be perfect and there would be some difference? I think I'm overthinkjng this.... Lol......
Ok you are over thinking it, but only enough to miss the obvious not enough. The problem is here -"connected electrically". How is the manifold and rad electrically connected? They use a rubber or silicone insulator to connect them.
You DO however have a cast iron block electrically connected (bolts) to an aluminum cylinder head, with a common electrolyte. End of the day the corrosion inhibitor takes care of it.
Users browsing this forum: No registered users and 54 guests
