NitroDann's Long Awaited Garage Thread
monty007
Re: NitroDann's Long Awaited Garage Thread
Postby monty007 » Wed Mar 06, 2013 9:16 pm
Amazing build...well done Dann!
2004 SE
gslender
Postby gslender » Wed Mar 06, 2013 10:26 pm
Dann, am I reading them correctly in that it doesn't make 140 HP until over 4000
Postby NitroDann » Wed Mar 06, 2013 10:29 pm
Correct, Not many are making a lot more but work is being done to regain a little low end, it was designed to make mid and top which it sure does but id like to regain some mid, even if just to learn, as it wont do anything on the track with power at 3k.
taminga16
Postby taminga16 » Wed Mar 06, 2013 10:47 pm
Well done Dann.
"these are a beautiful set of numbers". Paul Keating. 1990
Greg.
wozzah1975
Postby wozzah1975 » Fri Mar 15, 2013 10:56 pm
Dann, thats a very good result, set up must be good. It's a credit to you.
Woz
Sean
Postby Sean » Sat Mar 16, 2013 1:06 am
NitroDann wrote:The tuner occassionally interjected to say he felt I was doing good or that I needed to try to get the AFRs more stable but 90% just operated the dyno.
Looks like it needs a little smoothing towards the end, but a solid number either way dude.
Intersting to see boost limited to 22ish?
I was able to get a few more from mine but make slightly less power, I guess the pressure means not so much as the amount of air means...
What sort of TB is it running?
Postby NitroDann » Sat Mar 16, 2013 1:12 am
The highest pull wasnt the final run. The bit at the end was flattened which doesnt affect the peak HP area, but no other run made over 324rwhp.
There is a 4 page argument over at MT if you want to see people misunderstand what I said above.
It was smoothed at the end and ONLY 3500rpm onwards and 4psi onwards was tuned. Still needs a day on the road to finish it.
The less boost the better flowing the setup is, take this and put it on a 325rwhp N/A engine and do it at 0 PSI.
It has a completely 100% stock inlet side right down to the factory 55mm TB.
M1474
Vehicle: ND - Turbo
Postby M1474 » Sat Mar 16, 2013 1:24 am
Awesome figures Dann, you should be very proud.
GHETTOCET
Sean
Postby Sean » Sat Mar 16, 2013 1:06 pm
NitroDann wrote:The highest pull wasnt the final run. The bit at the end was flattened which doesnt affect the peak HP area, but no other run made over 324rwhp.
Cool - Not on MT, not my type of forum...
pushing 325 through a stock intake side is borderline, you may well find that's your flow limitation.
Postby NitroDann » Sat Mar 16, 2013 1:08 pm
The turbo is rated for like 280crank hp, I d say thats the main limitation haha.
Sean
Postby Sean » Sat Mar 16, 2013 1:16 pm
NitroDann wrote:The turbo is rated for like 280crank hp, I d say thats the main limitation haha.
I've saw mine make similar, like I said earlier we got slightly more boost out of it, but round the more boost didnt aid in more hp back to back, it just made things get hot...
We'll see when you put the EFR or something else big on it I guess. EFR results are no doubt hotly anticipated by many. Should be sweet.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Mar 17, 2013 7:36 am
What boost do you plan to run for track work?
I can see the driveline needing some upgrades.
Postby NitroDann » Sun Mar 17, 2013 7:50 am
It will be on megasquirt ebc, still running 22psi ish.
It has a NB driveline in it.
Not sure what will break from here. With a good set of solid mounts and some braces from chassis to engine to stop it twisting around a lot it should be ok I hope.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sun Mar 17, 2013 9:21 am
The race cars running 16-18 PSI have broken axles, diffs, gearboxes... Solid engine mounts certainly help. Front hubs don't last long if its running big brakes, also need to keep an eye on the front cross member, have seen them cracking around where the control arms mount.
Postby NitroDann » Sun Mar 17, 2013 11:02 am
Thanks a lot for the advice, mr Gough has warned me of a lot of that.
It has some huge 8..maybe 6 piston AP's on it.
perhaps we should keep some spare driveline components.
The yanks seem to go ok at these power levels, Ive read no diff or axle issues but 6 speeds become a 2 season wear item.
It will be interesting to see, because this car has a LOT of torque.
Users browsing this forum: No registered users and 25 guests
