NitroDann's Long Awaited Garage Thread
- Sean
Re: NitroDann's Long Awaited Garage Thread
looks much better tidied up!
- Dweezle
Damn. So jealous.
That is perfect!!
Though i question the MX5 Mania name still on the car.
Seems a bit unfair to you.
Makes it look like they built that weapon!!
That is perfect!!
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
Yeah its way out of tune I know.
Dyno booked for friday.
Listen to my footsteps to get an idea how quiet it really is.
What a sleeper
- MrRevhead
Sounds quiet and free flowing from what I see/hear in that video. Also, I can hear the turbo starting to spool up!NitroDann wrote:
What a sleeper![]()
Well done Dann!
Looking forward to some results (track or drag based)
- 16bit
looks really nice, well done.
New avatar
- 16bit
very nice, what was the previous record?
310, by a fully built 1.8L with a tubular manifold and 3" exhaust, worked head and a customer plenum and throttle body
Used to make 200whp at 4000, now it makes 300 at 5000 all the way to 8000.
- 16bit
wow, congrats. i assume you will post a graph in good time.
Apparently I can go and get a printout in person with all the info next week.
The whole top flat part is over 300whp, did this run on 17x9 wheels and tyres also.
The intake everyone hated was 25 HP better than an open turbo, and 20hp better than bonnet up dyno fan on and no filter on an open 3" pipe.
at what PSI Dann?
Same as last time
ALLOFIT
22psi was everything it had, it was the T25 that could
ALLOFIT
NitroDann wrote:Same as last time
ALLOFIT
22psi was everything it had, it was the little T25 that could
Fixed.
- gslender
....and Dann, what ecu was used, and did the tuner do the work or did you?
G
G
- PaulF
It's a T25, the "little" is implicit in the name.
Congrats Dann. Will be good to see what it can do at Wakefield with the new aero as well as the new turbo setup.
