Dale good find. How do you fit it, cable ties?
I will post this elsewhere too but what I don't get is the flammability of the foam -rubber is flammable, is this treated foam?
Wheel and Suspension Facts And Figures
Re: Wheel and Suspension Facts And Figures
Used cable ties here. Don't know if it's treated, however given it's being sold by Revolution Race Gear I'd expect it to be suitable for track purposes, but haven't confirmed this.
- erskimo
Able flex, boys and girls, it a foam product that comes in different sizes 100mm x 10mm x 6m, 150mm x 10mm x 25m (if I remember correctly) its got a 'sticky back on one side its used in construction. It may help
baaaRINGGG dadinggg ding ding
I'd be wary of using pipe lagging over proepr rollbar padding.
Rollbar padding is quite firm in order to absorb the impact from a decent speed.
Pipe lagging (all the stuff I've seen anyway) seems to be a lot softer, and won't protect you much in an accident.
Basically, if you can compress the foam easily with your hand, you'll also compress it even easier with your head at 60+kph.
hks_kansei wrote:I'd be wary of using pipe lagging over proepr rollbar padding.
+1 on this..
The FIA stuff is that stiff that it makes it difficult to fit into the car, and a pain to fit around corners. (I ended up having to cut into triangles to fit around the cage bends)
The upside of that is that it absorbs the forces more appropriately when a helmet slams into it..
The soft foam mentioned above, may be easy to fit but wouldnt be much better than the bare bar with respect to cushioning an impact..
Not at the moment FIA approved but if it is good enough for a motorcycle helmet and motorcycle race suits http://www.d3o.com/d3o_products/plain-and-mesh-sheet/
- MattR
But unfortunately not acceptable for use in CAMS racing events as it is not FIA approved.
It may be fine for sprints but that would be up to the scrutineers at that event.
- Custardtart
Having hit my head on both I vote for the proper stuff. Can also save your helmet at relatively low speed impacts
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
