NC Shocks.
JayMo
NC Shocks.
Postby JayMo » Sat Jan 05, 2013 9:45 am
Hi wondering what the goss is on shocks... i have three black and one yellow on my car :shock: (previous owner) and they are possibly a little tired...
I need the stock NC "SUV spec" ride-height so i will be leaving the springs alone... i am after bang for the buck, but want good quality jobbies (ie koni? Billies?) i want to have good control without being overdamped....
And what is a good installed price for 4?
thanks in advance
John
NC1, Black & Tan, Cow & Canvas
Mazda3 SP25GT, Soul Red Metallic
Charlie Brown
Re: NC Shocks.
Postby Charlie Brown » Sun Jan 06, 2013 6:11 pm
Gloss, my guess they are leaking oil.
Go to Goodwin Racing site and order some Tokico HTS shocks plus the rear Adjustment cables.
They will cost you less than getting the stock shocks from Mazda.
Installation cost, 4 hours labour.
Re: NC Shocks.
Postby Regie » Sun Jan 06, 2013 6:26 pm
Yep what CB said
the Tokiko shocks are pretty good...and cheap!
Sailor
Re: NC Shocks.
Postby Sailor » Sun Jan 06, 2013 6:37 pm
Or buy Neils Yellowspeeds
Rob
JayMo
Re: NC Shocks.
Postby JayMo » Fri Jan 11, 2013 9:11 pm
Thanks Gents
flat out, so i don't get to check in every day....
I just haven't been interested in coil-overs... I have to be able to negotiate the in-laws farm... so I would like to keep stock ride height, spring rate and suspension stroke length... not sure coil-overs (let me know if otherwise) will do that hence just after shocks... i actually want to keep it SUV spec...
Fully Barge! :twisted:
John
neilhr
Vehicle: NC - Supercharged
Re: NC Shocks.
Postby neilhr » Sun Jan 20, 2013 10:33 am
hey Jaymo, I sent you a private message
JayMo
Re: NC Shocks.
Postby JayMo » Thu Jan 24, 2013 5:55 pm
Thanks for the pm's
Still seeking commentary about yellowspeeds at stock height versus stock setup at stock height as the spring ratios front to back (from what I have read) are different?
Anyone ever go back to stock after yellows or similar?
Plenty of non mx5 driving mates are telling me coilovers are "harsh", I want the car to stay balanced...(if I go the yellows I may not be able to help myself and take a speedhump/driveway dependant inch out of it for the daily comute... and wind them back up for the farm)
The other thing is it appears that the top hat has been flooged out (I have a knock) by a loose strut bolt maybe? (speculating), are these things bushed or easily sourced/replaceable?
Thanks in advance for the advice...
Regards
John
Re: NC Shocks.
Postby Regie » Fri Jan 25, 2013 9:50 am
Im running yellowspeed at the recommended spring pre load, my car has been lowered. The ride is a fair bit more harsh than the standard shocks...then again the standard shocks are utter shiet. If you don't want the harshness id go the Tokiko HTS adjustables, My uncle has them on his NC and they are a nice shock at std ride height.
If you are still thinking, im sure I could organise for you to head down my way (Peakhurst) and ill get my uncles NC here and I can take you for a spin in both and you will have a direct comparison then :)
JayMo
Re: NC Shocks.
Postby JayMo » Tue Jan 29, 2013 9:57 pm
Hi, Thanks for the offer, I am so time poor at the moment with 2 roles at work (for another month), two kids (no relos within 5 hrs drive) + renovations...
Considering ordering the Tokico's and rear adjuster cables... read about cars sometimes getting a reverse rake on aftermarket shocks... (due to gas pressures in the cans) is your uncles sitting flat?
also still considering the second hand oems that have been tabled (thanks guys)
I have about two days to come to a conclusion... so this drawn out boring thread will sort itself out :roll:
thanks guys
JayMo
Re: NC Shocks.
Postby JayMo » Sat Feb 16, 2013 2:06 pm
After gettin an edukation reading this thread
Coilovers and swaybars question - NC viewtopic.php?f=30&t=56453
I decided to stick with OEM.
Thanks to this great community, I was able to get a full set of OEM low mileage bits including the top hats (mine were flogged) bumstops, boots etc... and I got to admire a noice NC1 to boot! :wink:
John
Re: NC Shocks.
Postby Regie » Sat Feb 16, 2013 9:23 pm
JayMo wrote:After gettin an edukation reading this thread
John
might be a bad choice..unless they were very cheap/free... many NC1 drivers have leaking shocks after 30 000kms or so. My uncle had 2 leaking shocks within a few months around the 35 000km mark
JayMo
Re: NC Shocks.
Postby JayMo » Tue Feb 19, 2013 9:47 pm
Thanks Regie
Well, they are in now... and WOW :shock: so this is how a standard NC is meant to handle!
It now grips like an eight legged cat!
If I get 30 to 40k out of em that will be enough, by then I might know what I want to do with this car and what to put in it... getting it to a nice stock standard is the plan at the mo...
It used to roll steer like a bugger, guess that having floating strut tops... and four shot shocks (well, at least one of those was a Bilstein) doesn't help.
Re: NC Shocks.
Postby Regie » Tue Feb 19, 2013 9:53 pm
nice work, now get it to Spinning Wheel for a decent alignment and you will be in heaven
Users browsing this forum: No registered users and 218 guests
