Piston rings recommendation
- gslender
Got std pistons, but wondering what folks use for piston rings? Anything strongly recommended, or just use whatever Repco flog you?
G
G
Re: Piston rings recommendation
Does this mean we can buy a ring grinder?
- gslender
toppertee wrote:Does this mean we can buy a ring grinder?
What for?
gslender wrote:toppertee wrote:Does this mean we can buy a ring grinder?
What for?
You have to grind the rings to fit. Plus I'm no good with a ring file.
- gslender
Dremel baby.... It does everything!
G
G
Just get a set of ACL rings, BUT you will need to measure what thickness the oil control ring is 3mm or 4 mm, and order as required.
You will need to measure ring gap in the bore but I doubt that they will need filing as the std bore used with a hone will probably be at max diameter.
If you don't know how to do this I'll try and find some training info and post.
Terry
Terry
gslender wrote:Dremel baby.... It does everything!
G
Got one of those already!
I need some more tools....
- Zcootz
I went with gapless rings on my last build and never looked back. They only cost a fraction more than the cast iron.
Out of interest I wonder who makes ACL rings these days, I used to do some engineering work for them when the rings were still being machined in Melbourne?
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Murray Walker
- Matt
- Learner Driver
Hastings made the gun rings back when I was in the trade. Not sure if they're still available, but I used them a lot and found them excellent.
- wozzah1975
+1 for Hastings. If you are using the OE pistons and just honing the bores make a point of just using a cast type ring in it, not a moly or anything fancy.
Woz
Woz
Bit of a bump from the past, but its relevant to my situation today.
I am reconditoning my MX5 motor, and the gaps from the old rings were within spec from new - 0.25mm off the top of my head.
The new piston rings I got from hastings are at 0.50mm !
Would you use these new rings?
Where can i buy some rings that will fit my car, I have already exchanged these rings once due to poor ring gap.
I've got NPRs off eBay for std pistons and lightly honed bores. 40,000kms on those now, including 5,000 track - still have 210ish compression, no smoke.
What type of ring end gap did you run magna?
It's manga, not magna.booki89 wrote:What type of ring end gap did you run magna?
I just ran with Mazda factory specs.
Source: Mazda NA8 Technical Data at http://mx5cartalk.com/forum/viewtopic.php?f=76&t=46376
The NPRs were SWT20066. Google that for dimension data. They were easily in spec straight out of the box. No grinding or filing needed.
Engine had 170,000 kms on it then with little or no visible bore/piston wear. It was overhauled because of a crank nose failure.
Thanks manga, these are the same specs I am shooting for.
My Hastings rings are getting me 0.5mm gap on my top rings and even larger on my oil rings, so I am hesitant to run them.
Will be looking for another brand....as the rings that came out of the engine were within that factory spec!
Users browsing this forum: No registered users and 59 guests
