coil on plug on 2002 nb
Kuncha
Postby Kuncha » Wed Feb 06, 2013 10:39 pm
Having an issue with a occasional misfire.
Is it recommended to stay with original Mazda coil on plug or do i change to ???
Many thanks
Frank
Hjt
Re: coil on plug on 2002 nb
Postby Hjt » Wed Feb 06, 2013 11:31 pm
Could be various issues.
Postby 93_Clubman » Thu Feb 07, 2013 3:17 pm
Kuncha wrote:Having an issue with a occasional misfire.
NB8B CoP is usually reliable so most owners stick with it. Might be time for two new leads though.
Postby manga_blue » Thu Feb 07, 2013 3:26 pm
You can change to Toyota coils but most of the ones that people here use on their MX5s are too fat to fit down the barrel of the NB8B head. There is one model of Toyota coil which does fit (from a V6 Lexus SUV) but you most likely have to buy them from Japan and do a fair bit of re-wiring to connect them up and make up a mounting plate to hold them down and worry about adjusting voltage or dwell time so that they don't blow up. :frown: :frown:
So basically check the 2 HT wires on the coils you've got and if you still need to replace coils then use the OEM Mazda ones.
Postby bruce » Thu Feb 07, 2013 3:30 pm
Spark plug leads!
(change the non-coil part).
Postby 93_Clubman » Thu Feb 07, 2013 4:16 pm
:mrgreen:
de Bounce
Postby de Bounce » Thu Feb 07, 2013 5:39 pm
Depends on when the misfire happens.
By all means change the CoP's if you believe them to be the problem.
I would try some of the known issues with the NB8B like the Cam Angle Sensor!
Motorkhana Video
Kuncha
Postby Kuncha » Thu Feb 07, 2013 9:28 pm
Thank you for all the assistance.
Users browsing this forum: No registered users and 55 guests
