timk makes up for talent with an EFR
Suspense
Re: saboteur's NB
Postby Suspense » Sat Feb 02, 2013 9:46 pm
^ Get RaceChrono on Android.
zero00
Re: saboteur's NB
Postby zero00 » Sat Feb 02, 2013 11:41 pm
mx5002 wrote:sounds good,
i wonder if they have an android equivalent. :|
Not sure, but google 'Harrys Lap Timer' and have a look - beauty is that you can also look up others lap times so long as they had it running - I think it was $19.99 to purchase
Roger D-SUNSHINE COAST
timk
Re: saboteur's NB
Postby timk » Sun Feb 03, 2013 12:34 am
gslender wrote:Looks good... What ecu do you run?
Thanks Grant, I'm using the stock ECU reverse engineered and dyno tuned by Lachlan Riddel. The results are pretty impressive!
gslender
Re: saboteur's NB
Postby gslender » Sun Feb 03, 2013 7:31 am
I take it you go back for any further modification/change to the engine? Overall, how has the cost compared?
Also, what logging or gauges do you have with that?
G
timk
Re: saboteur's NB
Postby timk » Sun Feb 03, 2013 4:20 pm
gslender wrote:I take it you go back for any further modification/change to the engine? Overall, how has the cost compared?
If it was something fairly substantial then yes it would require a retune, not unlike any other ECU. It is however based on flow instead of pressure so it can deal with small changes a little more intelligently than MAP based systems.
I'm a little confused about the cost comparison? Do you mean compared to my previous cars running stand alones?
gslender wrote:Also, what logging or gauges do you have with that?
It has a k-line serial interface but it doesn't seem to follow ISO9141. The later model MX-5s can use an OBD2 interface to grab data.
timk
Re: saboteur's NB
Postby timk » Sat Feb 16, 2013 2:47 pm
The oil cooler is here and mounted up, just waiting on a new sandwich plate for it before the lines are made up:
I have the Mocal sandwich plate but I wanted to keep the remote oil filter location, so MX-5 Plus are sourcing a GReddy/GREX remote oil filter mount with built-in thermostat.
TieNN89
Re: saboteur's NB
Postby TieNN89 » Fri Feb 22, 2013 5:42 pm
YAY more go fast bits :D
I miss the oil relocation kit :( it was the best thing ever IMO
MINX
Re: saboteur's NB
Postby MINX » Fri Feb 22, 2013 6:53 pm
Tim
Where is it going to be mounted?
rxmx
Vehicle: NA6 - Turbo
Re: saboteur's NB
Postby rxmx » Fri Feb 22, 2013 11:25 pm
clean setup you have, what sort of oil pressure you seeing on the track with the VVt pump?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
timk
Re: saboteur's NB
Postby timk » Mon Mar 04, 2013 8:12 pm
Stu, it's using the Flyin' Miata brackets so it mounts on the steering rack. Here's a pic with it all mounted:
Jason at MX-5 Plus made up the -10 lines for me, I didn't use the FM -8 ones. I'm using a GREX thermostat sandwich plate as it has provisions for my oil temp and pressure senders.
MINX
Re: saboteur's NB
Postby MINX » Mon Mar 04, 2013 8:53 pm
Are you leaving the oem splash guard on?
How will it get ventilated ?
I have a cutout in my splash guard - dunno if it helps
Re: saboteur's NB
Postby Lokiel » Mon Mar 04, 2013 9:33 pm
Consensus on MT.net is that it needs ducting to be effective - FM even recommend it.
timk
Re: saboteur's NB
Postby timk » Mon Mar 04, 2013 10:51 pm
I haven't ducted mine but it sits a lot more upright than your one Stu. The next track day will dictate if I add ducting or not! :lol:
timk
Re: saboteur's NB
Postby timk » Thu Mar 07, 2013 10:29 pm
Got some new shoes for street use, I was going to go for KU31 tyres but the price of the RE002 was right so giving them a go:
MINX
Re: saboteur's NB
Postby MINX » Fri Mar 08, 2013 7:49 am
mmmmmmmmmm chunky
Users browsing this forum: Google [Bot] and 5 guests
