Hoodedreeper's Eunos Roadster
Re: Hoodedreeper's Eunos Roadster
Small update:
- Vacuum Hoses now changed to black
- Clear P-Clips on Rocker Cover now Black
- Polished Expansion Bottle Cover
- Black Oil Catch Tank Fitted
Stoney Racing 14pc Ancilery Silicone Hose Kit (started to fit them,but need some more hose clips)
I won a Polished Slam Panel off ebay for £16
My custom Black Dials from Rlawton-Designer on MX5 Nutz arrived and fitted them today:
Still needing a 1.8 diff/driveshafts/prop,but with it being off the road and Christmas only round the corner i'm in no hurry
Heres a crap photo of them illuminated,realised i need brighter bulbs! For some reason 1000rpm doesnt light up,but does if i switch between sidelights/dipped...strange (never done it before) Guess thats something else i need to fix
Update!
About a month ago Speedhunters were on the look out for photo of MX5/Eunos/Miatas from all over the world. I emailed them some photos of mine on the off chance,knowing that it wouldnt get picked. The article went up and low and behold mine had been chosen! (about half way down)
http://www.speedhunters.com/2012/11/miata-featurethis/
My LED bulbs came through the post so got round to fitting them in the dash. They light up a treat! Just need to trim abit of the dash to light up the bottom left corner abit more,but who needs to see under 2k rpm anyway
(forgot to clean the perspex lenses...oops!)
Yesterday was an early Christmas for me
Alloy Radiator from Japspeed
Twin 10" Slim Fans
1.8 Open Diff,Driveshafts and Propshaft
Alloy Washer Bottle
Today me and a friend fitted the Radiator
I forgot i needed the fan shroud,so i fitted the original fan back on for now untill i can get some.
Also fitted an Alloy Washer Bottle from MX5Dan
Even had time to split the 1.8 diff and cleaned it up ready for drifting. Didnt realise how much of a difference there is between the 1.6 and 1.8 diffs,looks like the 1.8 diff will be ALOT easier to weld up Happy days!
Twin 10" Slim Fans
Alloy Washer Bottle
She's Back! I've been abit busy
Bonnet Pins and Aero Cups
Collected my custom centre console from the fabricators and mocked up the switches
DEPO Oil Temp Gauge
Stoney Racing Silicone Radiator Hoses
The car was down at H&S Performance to have the Steering Rack replaced (had been leaking since Summer '12) and for me and mate to fit the 1.8 Welded Diff,Driveshafts and Prop
Ordered a new Intercooler Kit from MX5Dan on MX5 Nutz. I ordered the Medium Size Intercooler
Comparison of the two Intercoolers
Throttle Body take off Assembled
And fitted
Turbo Outlet assembled
And fitted
Can see the new bottom radiator hose fitted,and heres the other rear one
I've missed boost too much,glad its back on the road (at last!)
And fitted
And fitted
A random photo from the other night...
Went to a Rolling Road day today
Outside waiting to go in
Just about got on the rollers,even with the bumper off!
She made 181bhp at the Fly and 158lbft. Very very happy!
And a lil video with the GoPro:
http://www.youtube.com/watch?v=JoNH2p-a ... e=youtu.be
- Regie
- Vehicle: NC - V8
great pics
its amazing what the salt on the roads does to your underside of the car
- zero00
Regie wrote:great pics
Would be a problem Regie, not sure what the salt does to snow but glad it don't snow here!! Then again that NA could be up to 23-24 years old by now
Roger D-SUNSHINE COAST
Shes a 1991 so 22 years old
To get the tacho to completely light up you need to break up some of the plastic behind the gauge face.
As per revlimiters write up.
its about half way down the page.
http://revlimiter.net/mods/gauge_install.php
The MX5 passed the MOT today,so another 12 months of motoring on its way!
Treated myself to a GoPro Hero 3 a few weeks ago. Only just got round to buying a new memory card and have a mess about.
My Mocal 13 row Oil Cooler,Thermostatic Sandwich Plate and Braided lines arrived today:
Will be starting on the re-wiring of the centre console in just over a week's time,so hopefully that'll be done soon
Look forward to the footage
- timk
I had the same issue with the cluster lighting:
I think any cluster housing that doesn't come standard with a "resting 6 o'clock" position will have this issue. But like you've said, who cares about that part of the rev range!
timk wrote:One other change I've made is swapping to a JDM tacho; it makes the redline area much easier to see with your peripheral vision on track days:
It is an easy swap to do however you will find the 0-2 area not as well lit as the rest of the gauge. The Australian cluster doesn't have anything in this area so there's no provisions for a bulb or light to get through. I don't find it to be a problem.
Ordered a new Number Plate bracket from Jass Performance because the old wonky one was doing my head in!
While i was out and about i tested out the new GoPro and caught this image
You may remember me cutting my dashboard about and the Custom Centre Console i had made up. Me and a friend finally got round to fitting/wiring it!
Still need to tidy up a couple of things but its almost done. As you can see we pulled the carpet out while we were there too
Users browsing this forum: Zedric and 179 guests
