FUEL SURGE??
Bathurst00
FUEL SURGE??
Postby Bathurst00 » Fri Jan 25, 2013 9:57 pm
I gave a NA8 and on high speed left hand corners with halk a tank of fuel I get fuel surge! Obviously on a race track but is there any clues as to what might be happening in my tank??
Davo 0415760760
gslender
Re: FUEL SURGE??
Postby gslender » Fri Jan 25, 2013 10:05 pm
Maybe it isn't the tank? Fuel rail?
G
Re: FUEL SURGE??
Postby NitroDann » Fri Jan 25, 2013 10:29 pm
Wow type slower :p
So you are saying that you are getting surgery on left handers on the track.
This is caused by either a dead or dying pump or by an incorrect non factory pickup sock filter. Or incorrect fitment of the oem intake sock filter on the pickup.
Muzdaman
Re: FUEL SURGE??
Postby Muzdaman » Fri Jan 25, 2013 10:35 pm
Dont forget to check your fuel filter too.
Re: FUEL SURGE??
Postby 93_Clubman » Sat Jan 26, 2013 1:54 pm
Russellb explains here with pics:
viewtopic.php?f=29&t=45597&p=575578#p575578
015CAR
Vehicle: NB8A - Turbo
Re: FUEL SURGE??
Postby 015CAR » Sun Jan 27, 2013 3:06 pm
Hi Davo,
I have the same issue. Only on left handers, only when at max lateral g's and pretty high revs. It was doing it coming out of Hungry at Lakeside in third, but backing off a bit by running 4th stopped it... Although the advice from others above is the generally accepted solution, it does not seem to be my issue. Still working on this... I have a aftermarket pump, but it has the correct sock, and I have done my best to ensure that it is positioned correctly at the bottom of the tank-and mine will do this on three quarters of a tank, so I'm starting to look at other things- although I'm buggered if I know what yet.
Sorry I'm not giving you a solution- but I will watch to see if someone gets you sorted...
Rich.
QR clubman 64.93 - lakeside 67 neat- first time out...
Re: FUEL SURGE??
Postby NitroDann » Sun Jan 27, 2013 3:29 pm
I never sorted the surge my last car had before it was destroyed. have you used a fuel flow tester to check if the pump is both providing the pressure and the flow?
It doesnt seem likely the cause but gees who knows. the other thing to consider is an electrical fault that happens due to the inertia, like a loose wire.
Its an annoying thing to deal with I know.
Re: FUEL SURGE??
Postby 93_Clubman » Sun Jan 27, 2013 4:02 pm
NitroDann wrote:It doesnt seem likely the cause but gees who knows. the other thing to consider is an electrical fault that happens due to the inertia, like a loose wire.
Could be the 'blackwire' issue:
viewtopic.php?f=55&t=46425
Matty Hall had similar problem, but not sure if he fixed it:
viewtopic.php?f=29&t=55011&p=694099
