Camera mounts for motorsport
Kuncha
Postby Kuncha » Thu Jan 24, 2013 7:07 pm
I have just purchased a mx5 for track work and need to source some camera mounts for bullet style cameras.
Any information regarding suppliers will be greatly appreciated.
Re: Camera mounts for motorsport
Postby Magpie » Thu Jan 24, 2013 7:10 pm
Do you want a roll bar mount or a windscreen mount or outside the car?
What sort of mount does it have? A normal tripod mount, gopro, contour or Vbox?
Do you need to run power to it?
Postby Okibi » Thu Jan 24, 2013 7:14 pm
Do your bullet cams have a thread to secure them to a tripod / camera mount?
Postby Hammer » Thu Jan 24, 2013 7:16 pm
Not sure what mounting component your camera has (tripod screw type?)... but here's one that I use in both motorsport and when I go sailing.
http://www.ram-mount.com.au/
But I've just started using GoPro Hero 3 for my racing activities and thus I use GoPro's own mounting hardware. But I still use RAM mounts for my sailing activities and they work extremely well.
Kuncha
Postby Kuncha » Thu Jan 24, 2013 7:31 pm
The cameras have a thread in the back but i prefer to use a saddle type mount.
I need a rollbar mount and another to shoot thru the windcreen.
I prefer not to use suction mounts as i want to have them permanently mounted.
Thanks for the quick responses.
PT
Postby PT » Sun Jan 12, 2014 11:02 am
I've got a similar question.
I've got the mx5 plus twin hoop roll bar. I mounted the gopro on a sticky mount to the top of the torque box of the roll bar but it's too far back and sees the back of the seats. So I used the extended mounts that you would use to mount it sideways, but had them straight to mount it up and forward. The view was good but shake of the camera on bumps made the footage unusable.
I'm interested to see what other people have done to mount the camera in car and what the view was.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
zossy1
Postby zossy1 » Sun Jan 12, 2014 11:11 am
PT wrote:I've got a similar question.
You need a gopro roll bar mount. They are awesome, mine survived the rigours of karting (secured to my radiator cap!). Even had a guy drive over me once, camera survived.
PT
Postby PT » Sun Jan 12, 2014 2:59 pm
I went out and bought the gopro roll bar mount.
It fits the tube size perfectly, however, as I have the twin tube roll bar, I can't get the camera into a position where it doesn't just see the back of the seats. Back to the drawing board..... Again.....
I thought about mounting it to the underside of the hard top, but then it's pointing at the rear view mirror and that's all it gets.
The position I had it in on the top of the torque tube with the extension pieces presents a good view, but the wobble is too much. I've ordered the GoPole but I don't hold high hopes for it not wobbling too. I'll grab a couple of photos of what I'm trying to achieve.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
PT
Postby PT » Sun Jan 12, 2014 3:19 pm
This is where I've had it so far. The view is this:
Which isn't too bad, sees a little more of the seats than I would like but is ok. Problem is that the combination of extensions to get it higher and forward are producing a shake in the camera that makes the footage unusable.
This is the view when using the roll bar mount. The problem is the seat is right in front of the tube so I've got nothing back there to mount to. I could keep adding extensions but the result is likely to be the same.... Wobble.
I need a magic wand.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Postby Okibi » Sun Jan 12, 2014 3:58 pm
I've tried 2 locations with my gopro rollbar mount
On the top bar
http://www.pixelculture.com/SE_28thDec2013_03.jpg
On the bottom bar
http://www.pixelculture.com/SE_28thDec2013_02.jpg
Bottom bar I think is the better off the 2 but I have some bits coming from ebay to mount the camera a bit higher to show the road/track ahead.
PT
Postby PT » Sun Jan 12, 2014 7:19 pm
I think we are trying to acheive the same thing. What have you ordered to lift it up a bit?
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Postby Okibi » Sun Jan 12, 2014 8:15 pm
If you search ebay for "gopro aluminium" there's loads of different bits you can get.
This is one of the bits i'm getting
http://tinyurl.com/ljh6njb
PT
Postby PT » Sun Jan 12, 2014 8:27 pm
I saw them too, I was worried that they would flex side to side so I didn't get them.
Let me know how they go.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
PT
Postby PT » Sun Jan 12, 2014 8:39 pm
This looks promising. http://tinyurl.com/ke23ua5
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Roadrunner
coyotes after you
Postby Roadrunner » Sun Jan 12, 2014 9:15 pm
On the Nb I mount my go pro with a tripod adaptor attached to a bolt through the hole between where the number plate brackets under the front bumper attach.
This is extremely solid, gives a great sense of speed and you can see the front splitter (and unnervingly how much it moves at speed)
MeepMeep
