Airconditioning Insulation
Re: Airconditioning Insulation
Postby bruce » Tue Jan 22, 2013 11:54 am
That is pretty dumb putting that rubber insulation next to the exhaust (I will have a chuckle when I see the fireys putting your car out on the news).
Like others have said, there is proper stuff you can buy.
timk
Postby timk » Tue Jan 22, 2013 11:57 am
Locutus wrote:i'm surprised how many of you are strapping mystery plastics in some of the hottest parts of the engine bay.
i hope you guys have practiced your fire escape procedures and have your extinguishers at the ready.
I hear ya!
timk
Postby timk » Tue Jan 22, 2013 11:59 am
bruce wrote:That is pretty dumb putting that rubber insulation next to the exhaust (I will have a chuckle when I see the fireys putting your car out on the news).
You must have missed my tongue-in-cheek comment at the bottom of that post. I don't even think it improved efficiency of the system at all! :lol:
I added a warning in case others missed the hint...
SalonRacing
Postby SalonRacing » Tue Jan 22, 2013 8:09 pm
If your fan flow is that weak you might have a bunch of leaves and crap in the intake, you can jam a vacuum cleaner hose down the intake behind the firewall and try to suck them out.
It's actually really easy to get the blower fan out, just pull the glovebox out and it's only a few screws but they are Torx heads from memory.
That aircon line runs directly beside the unsheilded exhaust housing on my car so I went to the wreckers and found some foam insulation with the reflective foil coating on the outside. It was a single piece on the car I removed it from but I just sliced it up the side and used stainless zip ties to attach it, it has the 90 degree bend formed in it already and looks pretty factory.
Postby KevGoat » Tue Jan 22, 2013 11:07 pm
NitroDann wrote:NA6 fans are actually ok, but no one has EVER replaced the filter on them. Thats why they sound like a clogged up vacuum cleaner. :lol:
...where's the filter?
Postby hks_kansei » Wed Jan 23, 2013 8:57 am
My partner is currently doing some work on her car and has that area pulled apart, can't see any filter...
Under the cowl plate there's a hole with a piece of mesh over it, it leads straight down to the fan (which is visible through the mesh)
ertert
Postby ertert » Wed Feb 13, 2013 10:23 am
Any update on this?
droo
Postby droo » Wed Feb 13, 2013 1:38 pm
Call it tempting fate or what not, but i haven't gotten around to trying anything different yet. Three other much bigger projects have cropped up which i've poured my attention into. But in the mean time, I've dríven to Melbourne and back quite a few times, I'm still enjoying my cold air, now travelled well over 2500km since first posting. Driving the highway for 30 minutes i have to turn it down as it's too cold inside. Hate me if you must.
There are still another 2 months of summer to go, and i'll see what i can do in that time. I'll write back my findings ready for the next critique.
