Jeo wrote:Don't forget the side impact too.
Yes, I've heard of people being T boned and rolled over.
Here's another thing I can do with the BD that I haven't seen done with the MX5 plus ones http://mx5cartalk.com/forum/viewtopic.php?f=28&t=18875
Earlybird wrote:Here's another thing I can do with the BD that I haven't seen done with the MX5 plus ones http://mx5cartalk.com/forum/viewtopic.php?f=28&t=18875
+1 on the brackets if availablesailaholic wrote:Hi Danny are those brackets available?
Earlybird wrote:sailaholic wrote:Hi Danny are those brackets available?
They look like the original windblocker brackets to me, just swapped around.
Unfortunately, I'm 6ft tall and it looks like this conversion would put my seat about 3" further forward which makes it a bit cramped for me personally.
Great mod though Danny and thanks for sharing, am sure others will benefit from this!
Earlybird wrote:Out of curiosity though, can you tell me how much clearance you have between your top edge of glass window and the bar in the down position? I have an aftermarket Robbins soft top which I fear may come to close to the mx5+ torque bar anyway.
My clearance from the top edge of the glass to the rear of the middle stud in parcel shelf carpet is 8cm.
zephyrus17 wrote:I just finished the install moments ago (after 8 hours..). A few notes, comments for those looking to install in the future:
3. Even though they tell you to drill the 8x 12mm diameter holes at the back, the holes in the roll bar were weirdly not 12mm diameter. So it was frustrating that I had to expand the roll bar holes there. It would be better to pre-expand the holes before I got to that step.
6. When the front 4 bolts were hand tightened, the rear 2 pads of the roll bar didn't align with bulkhead, and it was floating a bit the in air. I couldn't get one of the bolts to go into the right pre-existing hole because it didn't line up.
zephyrus17 wrote:I have a completely stock top, and it clears easily with about 1+ cm to spare.. I also read that there would be a loss of seat travel, but when I installed mine, the horizontal travel wasn't affected at all. Only lean-back was limited at the very extreme end.
zephyrus17 wrote:4. The big spacers ((5) in the manual) are uneven. One was about 3mm longer, and I had to cut that down.
Shambler wrote:zephyrus17 wrote:4. The big spacers ((5) in the manual) are uneven. One was about 3mm longer, and I had to cut that down.
As far as I understand it they deliberately did that due to one side being fractionally higher than the other ( that is if I'm thinking of the right part!)
I called mx5plus a few times during the install to make sure I was doing the right thing, there was definitely a few steps that weren't elaborated on in the manual that needed it!
deviant wrote:zephyrus17 wrote:I have a completely stock top, and it clears easily with about 1+ cm to spare.. I also read that there would be a loss of seat travel, but when I installed mine, the horizontal travel wasn't affected at all. Only lean-back was limited at the very extreme end.
I think that is the 'tall boy' bars only.
