Mexie & Kev say hello
Re: Mexie & Kev say hello
Postby KevGoat » Sat Oct 13, 2012 11:52 am
Mexie's discovering her masculine side ...
[img]://lh4.googleusercontent.com/-pXiIcuJ4lNw/UHqUEiZnNJI/AAAAAAAAgL4/NUSt7YGY4AA/s406/20121013_104858.jpg?gl=AU[/img]
Brown Davis fitted :!: :D
Must thank the guys at Formaz Parts Plus NSW, especially Mark, for all their help and service after all the fittings went missing during transit. Always great service from these guys every time I've purchased anything from them.
Bit fiddly to fit on my own but apart from a few cuts, some new words added to the English language and a sore back it goes in easily ... well ... that would have been the case had I not had to re fit some nuts/bolts on the passenger side after I found one of the backing plates that goes under the shelf still sitting happily on the bench while I was tidying up after I thought I'd finished :| :? :frown: ... can laugh about it now but .........
Postby KevGoat » Sun Oct 14, 2012 10:11 pm
So roll bar in ... NB windblocker out ... but I like my windblocker :cry:
I'd found the blocker quite functional in reducing the amount of breeze around the cabin since installing it. Great for top down cruising on colder days with the heater on. Probably would be on really hot days with the airconditioning on if mine worked lol :lol:
:idea: So had a look at it and thought what if I just turned it around, would it fit? Way too easy I thought. But would it even function turned around and angled in the opposite direction? Only one way to find out ...
It wedged in easily. I was amazed to find that the bolt holes lined up directly to the existing BD bolts! Quickly drilled out the blocker's holes to fit the larger bolts and fitted it in using the BD bolts. Didn't look bad! Even followed the lines of the BD Bar's rear stays nicely!
Tried the blocker with the flip lip up and with it down. Appearance wise, it's lines look better with the BD bar with the lip down, so I left it that way. Besides, fitted in this way it is just a 5 minute job to remove 4 nuts, shift the blocker & flip up the lip, fit it back in to place and replace the 4 nuts .... easy :D
With great weather in Adelaide today, my wife & I went for a pleasant cruise down the coast to Normanville. A beautiful hot, sunny day, but there was still quite a strong wind and despite that my wife was very pleased with the effect of the bar, saying it worked just as well as it had ever been!
Winner!!
With lip up :
With lip down:
Postby KevGoat » Thu Nov 01, 2012 7:32 pm
A few upgrades over last few weeks ...
Fitted a new NA8 Tombstone to replace the NA6 one, just 'cause I reckon they look nicer with the radio etc recessed ... oh yeah, at same time I also fitted a new Pioneer Bluetooth head unit. 30GB music on my phone so the BT Streaming is very desirable :D ...
Got sick of having to climb out so often to adjust my passenger side mirror because someone had knocked it walking past, so decided to fit and wire NA8 Power Mirrors. Ground down the locating ring on the mirrors, rattle can re-sprayed them to match my car, made up a loom to suit and wired them up using info from couple of forums. Mostly straight forward except thought I'd wired them wrong and kept checking for ages until I worked out the switch I'd purchased was faulty. Took it apart & fixed some faults inside, including a broken circuit, plugged it back in and yippee!! So a bit of a fiddly job but a very worthy upgrade ...
Testing the wiring (I decided to cut the plugs off & soldered all the wiring once all was working):
Next up my Thompson Products front lower chassis brace arrived. Very easy 15 minute installation & a very worthy upgrade to the feel of the car:
Until next time folks ..... :beer: :wink:
Postby KevGoat » Fri Nov 02, 2012 10:29 pm
So ... I found that after I fitted the BD roll bar, the stiffening effect that it had on the car, especially in the rear end, showed up deficiencies in the front chassis.
Ages ago, I fitted a cheap ebay strut brace, something poo poo'd by many :P But I bought it as it was cheap, looks good when I open the bonnet, and can't really do any harm :mrgreen:
Anyway, as mentioned, the BD bar had a great stiffening effect, but it also had a crappy effect on Mexie's front chassis. I decided to try tightening the strut brace to see if this would actually have any effect on the front end. Tried one turn each end, but not much difference, so turned even tighter and wow! to my surprise, it had quite a beneficial effect! Didn't sort it completely, but there was a sufficient difference in the feel to know that these things do actually have some benefit after all!
But by doing this it showed up that the car needed more sorting in the front end. So that is why, after much searching, I decided to try the Thompson Products front lower chassis brace. I really wanted the Racing Beat brace, but at half the price the Thompson brace appeared to be just as effective and had great reviews.
Having fitted the brace, the feel in the front end completely changed character once again! During all this I also developed a horrible vibration which felt like a wheel out of balance or a wheel bearing failing. I took Mexie in for a wheel balance/alignment and a wheel completely out of balance sorted my vibration issue, but when I drove out I had a bounciness that wasn't apparent before. Turned out they'd put 40psi in the tyres!! Ouch!! Also, since fitting the Thompson brace, the front end had become rather jittery. So when I got home and reduced the tyre pressures (geez!!) I also tried backing off the strut brace. I figured that now my chassis was stiffened, maybe the strut brace didn't need to be as tight? So after adjusting and test driving a couple of times, I found that setting the strut brace back to it's original setting made the front end feel great.
The result? Well, I'm no high performance driver as I've mentioned before, and I don't drive the car anywhere near it's limits, but to me the car now feels tight, nowhere near as much shaking through bumps and my confidence going further in to corners has improved hugely!
Amazing what a few cheap upgrades can do :D
So, can't help wondering what a nice set of coilovers, bigger wheels/tyres, lowering and some track time would do :lol: :roll:
Only a matter of time me thinks ......
Postby KevGoat » Tue Nov 20, 2012 5:39 pm
Big $$$ day today :shock: - had the airconditioning fixed.
New compressor, drier, flush & clean and everything else that was needed to get it working again. A dye was put in and will take it back in a week or two to check for any leaks. The airconditioner hasn't worked since I bought the car last year, so the system wasn't in the best of shape :?
Warm day today, about 33º and slightly humid for the short drive home and appeared to get fairly cold. Has the new gas, (the new fittings were already there apparently) so from what I've read it won't be as efficient as it could have been, but a hell of a lot better than nothing. At least I'll be able to demist during winter now :!: :lol:
Postby KevGoat » Sat Nov 24, 2012 1:12 pm
lol ... once again, fixing one thing leads to another ...
Now that my aircon is working, I found that the air vents flop around all over the place when I turn the fan on!!
So, out come a couple and try to work out how to get them apart. Found the easiest way was to put a wide blade screwdriver in to the area where the clips are and carefully but forcefully turn until it pops out. Scary, but didn't break anything :)
The bits:
There's thin felt type stuff inside that obviously wears, should be easy to find something to replace it.
Might spray the surrounds with some black paint while out to get rid of the faded look.
Postby KevGoat » Mon Nov 26, 2012 8:20 pm
Fixed my air vent slops ... carefully pulled out the existing felt type stuff, added some double sided tape to the back and just stuck them back in. The extra thicknes of the tape was sufficient to make them quite tight!! Easy fix!
The strips:
Add tape (cut off excess obviously) & stick back in and solved the problem nicely :)
Glass of Shiraz as shown is highly recommended, though a reasonable result may be achieved without..
These came today:
New speedo cable...
Thought I'd try some of this stuff...
So up she went yet again...
The new speedo cable should have been easy to replace, but this dufus didn't take notice of where the cable went under the dash when he pulled it out did he? So after fitting it to the gearbox then through the firewall, I then spent ages contorted at completely unnatural angles, trying to figure out how to make it reach the instruments! AARRGGHH!!! Finally found a way, but it just didn't seem as long as my old one, even when I pulled as much cable from under the car and though the firewall. Made it fit in the end but managed to make an easy job in to a real saga :? :oops:
In the middle of doing the cable, the Royal Purple Oil arrived. I thought I'd give this stuff a try having read so many good reports. Having done the Diff & Gearbox oils myself last time, all the bolts weren't as overtightened and impossible to loosen as they were when I first did it (snapped a Sidchrome spanner getting the gearbox filler bolt undone last time!!).
Just a quick test drive, and the gearbox felt very nice. Straight away in the driveway it slipped easier in to reverse! Will see how it goes over a couple of weeks and see if any real difference.
The new speedo cable sounded just as rattly inside it as my old one did, so I don't think I achieved a single thing out of that episode, except that I won't have to worry about it failing in the near future :(
emily_mx5
Postby emily_mx5 » Tue Nov 27, 2012 2:44 pm
Nice work on the mirrors, i've considered the upgrade many times.
Roll bar looks good too!
samx5
Postby samx5 » Tue Nov 27, 2012 4:55 pm
Great thread Kev, really enjoying your regular updates!
Was: 1988 Corolla 4A-GE Twin Cam, 1991 Laser TX3, 1995 Peugeot 306 S16, 2003 Astra Sri Turbo, 2007 SP23 Lux
Now:1999 NB8A, 2011 Outlander VR-X
Postby KevGoat » Tue Nov 27, 2012 5:32 pm
emily_mxV wrote:Nice work on the mirrors, i've considered the upgrade many times.
Thanks Emily. I didn't realise how nice these mirrors would be until they were fitted and working. Now they don't move every time the flamin' cat jumps on them :? I know many people just fit them and don't bother wiring them, but that would drive me nuts! For the small amount of fiddling its well worth wiring them up.
Next to the NB8B seats, the roll bar has been the most beneficial upgrade. Car felt so different after fitting it, so much tighter and of course it looks so good :lol:
samx5 wrote:Great thread Kev, really enjoying your regular updates!
Thanks Sam, glad you're enjoying it :P I often feel I'm posting pretty ordinary stuff compared to the many serious build threads out there, but its fun keeping it updated and hopefully along the way I have posted some little tip that helps someone else, as so many threads have helped me.
Postby KevGoat » Sat Jan 19, 2013 6:04 pm
Haven't done much to Mexie for quite a while apart from clean, polish and enjoy a few drives :wink:
But today, I purchased these BC BR's:
Bought them off a good friend of the lad I bought Mexie from, who has an NB. Got them for a great price, especially as they are virtually brand new!!!
Will be holding off fitting them to Mexie though, as after we talked for a while about both our MX's, I may also end up buying his NB from him! Will be checking it out probably next week sometime :D
ah yeah ... wife's gonna kill me ....... :roll:
Postby Lokiel » Sat Jan 19, 2013 7:29 pm
KevGoat wrote::
This seems to be a contentious issue on this site, some swear that the roll bar does nothing with regard to chassis stiffening, others swear that it really transforms the car. Like you, I'm definitely in the latter camp and consider it one of my best "modz" too.
Keep up the good work and documentation in the thread, including all the "f-ups" as well as triumphs, any "gotchas" and your own thoughts along the way, it makes great reading and helps others too contemplating similar "modz".
Postby KevGoat » Sat Jan 19, 2013 7:39 pm
Yeah it is contentious. Definately stiffens the rear, can't see how it wouldn't. Maybe not in a "performance" sense, but stiffer never the less. Mind you, as I mentioned, that in itself creates other issues in a 22 year old car!
Whatever anyone else's opinion, I fitted it, I like how it looks, I like how it feels :grin:
Postby KevGoat » Sun Feb 10, 2013 8:47 pm
Well, we have just returned from another enjoyable week's holiday touring in Mexie. Roughly 1500kms. The first day was the longest single drive - from Adelaide to Halls Gap via Kingston, Hamilton and Dunkeld. After a short stay in Halls Gap, we moved on to one of our favourite places - Port Fairy - then from there travelled to Robe for a couple of days then back home.
We only had the roof up on the first day, after we'd stopped in Hamilton for a coffee. We left it up through to Halls Gap, due to the strong gusty winds and heat. Despite a few more hot days, including the drive from Halls Gap to Port Fairy in 37 degree heat, the top stayed down :D
A few images from the trip:
We had a great time ....... though we were to experience a rather eventful finish to the trip....
On the way home from Robe, we stopped off in Meningie for a coffee. Mexie had run perfectly all week...until...
We'd climbed back in the car for the last stint home and she just wouldn't start! Cranked over but would not fire :(
After having a look around under the bonnet, I finally gave up and called the RAA. The RAA bloke's analysis was a problem with the ECU :shock: and told me they couldn't fix it for a couple days.
Luckily I have premium cover, which covers extended towing or accomodation or various other choices in such a situation. I asked to have Mexie trucked home, where I could take my time and analyse the problem. This was promptly organised by the RAA for us. Excellent service, wouldn't be without it.
Anyway ... to finish the story, we went round my mate's place that evening after arriving home and parking Mexie. It was his son I purchased Mexie from. I mentioned the problem to his son and he instantly told me what it could be. As soon as he said what he thought it was, I remembered having a similar problem not long after buying the car!!
The plug on the back of the ignition swtich had a faulty connection that I thought I'd fixed. Sooo ... This morning, I went out, removed two screws and the panel under the steering column, gave the plug that connects to the ignition switch wiring loom a push in, turned the key ... and started the car :oops: :roll: :!:
Embarrassing to say the least! Shame can't fix my shocking memory so easily ... :roll: :mrgreen:
PaulF
Postby PaulF » Mon Feb 11, 2013 2:36 am
At least you didn't get any further into your "ECU problems" before you realised the issue! Could have been a painful endeavour.
Users browsing this forum: No registered users and 121 guests
