i have a SE with only an inter cooler and the boost turned up to 9 pounds. i need injectors and dont know where to look or even what im looking for. i plan on running up to 15psi in the furture so need something to support that. i dont know much so any advise/ constuctive advise is welcome. THANKS!
James
what are good NB injectors
Re: what are good NB injectors
15psi is not a flow rate.
how much horsepower do you need to support on what fuel and ecu?
NitroDann wrote:15psi is not a flow rate.
gotta get alot of other stuff first, trying to find all the parts i need to" complete" the SE. goal is 180 rwkw, i fill up on bp98, still looking for an ecu :/
sorry not much info,
thanks,
James
Gonna do something like peters SE?
Throw on a T28 etc?
Throw on a T28 etc?
321cc injectors are the largest that the stock ECU can Idle correctly but these are VERY hard to locate.
It's easier to find 305/315cc Supra injectors (these seem to be the same injectors, it just depends on who's selling them as to what they market them as).
I have a set of 6 from a Supra that I used on my car prior to my 600cc injectors if you're interested (only used 4 obviously). Unfortunately I only have 4 of the rubber spacers left since I destroyed one when I initially installed them and lost the other one when it rolled into my engine bay, never to be seen again - ya gotta watch out for that. You only need 4 though.
Here's the best write-up on installing injectors I've seen so far: http://clubroadster.net/vb_forum/58-forced-induction-sponsored-kraftwerks-usa/27215-mazdaspeed-mx5-denso-321cc-23250-74050-injector-info.html
NitroDann wrote:Gonna do something like peters SE?
Throw on a T28 etc?
does he have a garage thread? and whats a T28 xD haha sorry
Thanks
James
Have a scan over the last 15 pages of my thread in the garage section.
If you start from here and read whenever you see pics of turbo parts you will get the idea.
viewtopic.php?f=57&t=47747&start=555
Its a lot of info, but it sounds like you need it.
- Steampunk
thanks! and oh yea i defs need it haha, thats y im here ^^
thanks
James
thanks
James
