Looking for standard NB8B rwkw figure
mazmad
Re: Looking for standard NB8B rwkw figure
Postby mazmad » Fri Jan 11, 2013 3:04 pm
I hear you. :D
In reality it is more to do with how your torque curve changes, and how that suits your driving needs (road, track etc).
evil_weevil
Postby evil_weevil » Fri Jan 11, 2013 9:00 pm
slightly off topic...
but same dyno/different day
my r33 mate 255rwkw and MX5 75rwkw
haha
viewtopic.php?f=73&t=62834
mazmad
Postby mazmad » Sat Jan 12, 2013 5:20 am
And I don't think that difference is due to atmospheric changes :shock:
geofiz
Postby geofiz » Sat Jan 12, 2013 9:21 am
mazmad wrote:And I don't think that difference is due to atmospheric changes :shock:
I think you will find it is all to do with the atmospheric change. The R33 just has more atmospheres than the MX5 :P
NB8A - mostly stock for now
mazmad
Postby mazmad » Sat Jan 12, 2013 10:34 am
Quite right sir :D
nbse2
Postby nbse2 » Mon Jan 14, 2013 1:45 pm
just had mine checked, mines an SE and it only registered 107kw which is pretty poor. Trying to get hold of the dyno charts from Deckspeed at the moment as with a bit of fiddling managed to increase the output/torque. Will do a more informative post once I get the charts.
mazmad
Postby mazmad » Mon Jan 14, 2013 1:53 pm
Post up a scan if you get it.
pcmx5
Postby pcmx5 » Mon Jan 14, 2013 1:57 pm
If it's a standard SE that is unbelievably high if it is RWKW .I am pretty sure standard SP's made around 114 RWKW at the Vic Club days over a 3 year period and they had around 30 more flywheel KW than the SE.
As always ,different dyno etc....
Peter.
Edit Just found Techno's records from 2003,4&5 Vic Club dyno days.
Peter.
Stock NA6's generally 58- 62 RWKW, NA8's 62-64 RWKW,NB8A's 66-69(a couple up around 72 but may have had mods,although Matty's made this power stock at another day)), NB8B's70-72, SP's 110-113. Some cars in each group made more but from my memory the quoted ranges are for standard cars averaged.
I know Chris Hoskin,s NB8B made70.3 in 2003 and about 74 later and then with exhaust and high flow cat got 82RWKW.All figures are from a Dyno Dynamics dyno
Postby 93_Clubman » Mon Jan 14, 2013 2:31 pm
nbse2 wrote:just had mine checked, mines an SE and it only registered 107kw which is pretty poor.
Presumably that's 107KW @ the rear wheels - if so that's good for a car that was rated at 121KW @ the flywheel. Deduct 10% for drive train losses gives you 109RWKW.
mazmad
Postby mazmad » Mon Jan 14, 2013 6:40 pm
10% loss is good given standard models lose 30%.
70rwkw yikes, bit grim isn't it.
Still, it's not what you've got but how you use it right? (been using that line on my wife for years.... :shock: )
Hjt
Postby Hjt » Mon Jan 14, 2013 7:00 pm
The SE should be around that figure, it was pretty piss weak in standard format.
Postby 93_Clubman » Tue Jan 15, 2013 1:03 am
mazmad wrote:10% loss is good given standard models lose 30%.
Indeed it's too good! Meant to say 20% approximation.
pcmx5
Postby pcmx5 » Tue Jan 15, 2013 5:05 pm
Techno's figures over almost 40 cars that were stock or lightly modified show a average loss of 30% plus,always assuming that the cars had the flywheel KW that mazda claimed in the first place!
Peter.
pcmx5
Peter.
Postby 93_Clubman » Wed Jan 16, 2013 10:36 am
pcmx5 wrote:Techno's figures over almost 40 cars that were stock or lightly modified show a average loss of 30% plus, always assuming that the cars had the flywheel KW that mazda claimed in the first place!
Pete, aware of Techno's figures, but I was going on Blackster etc figures which were SE specific.
Users browsing this forum: No registered users and 96 guests
