Strange Sloshing Sound??
spikes
Re: Strange Sloshing Sound??
Postby spikes » Sun Jan 13, 2013 12:24 am
checked your coolant level and bled your coolant system? open up your radiator cap and see if its full or not?
could possibly be coolant sloshing around in the heater core
Hjt
Postby Hjt » Sun Jan 13, 2013 9:18 am
I bet you have water trapped in and around your seals.
Jack the car up, get a screw driver and open up the drains that run along your lower door sills.
Google miata mx5 drain etc. Common issue.
aka_juffa
Postby aka_juffa » Sun Jan 13, 2013 9:44 am
Shkodrani wrote:Hello gang,
Also may be unrelated but at the start of that same day I heard tapping in the engine but this disappeared when warmed. The slushing sound does leave when warmed up but when cold on startup it comes back.
Thanks in advance.
Welcome to the obsession,
The tapping sound is the tappets. The tapping sound is used by many of us as an indication that the engine oil (and filter) needs to be changed.
More can be found here ==>> http://www.miata.net/garage/
J.
mrbrossnan
Postby mrbrossnan » Thu Jan 17, 2013 11:46 am
yeah i had the same sloshing sound that you described. turned out there was air pockets trapped on heater core lines when i flushed my radiator. ran the heater, took it for a drive & it dissapeared
Postby 93_Clubman » Thu Jan 17, 2013 3:27 pm
Welcome & good to hear you both got it sorted.
