RE THE BLUE TRIANGLE
geoffblick
Postby geoffblick » Fri Jan 11, 2013 2:06 pm
For track days does the blue battery triangle point inwards, i.e.towards the boot lid or downwards, i.e towards the wheel arch?
I am an inwards man myself but will stand corrected.
Re: RE THE BLUE TRIANGLE
Postby Jeo » Fri Jan 11, 2013 2:20 pm
I put mine on the boot lid and point it outwards.
JBT
Postby JBT » Fri Jan 11, 2013 3:12 pm
Put it at a slight angle and drive the scrutineers with OCD crazy.
Black_Penguin
Postby Black_Penguin » Fri Jan 11, 2013 3:16 pm
http://www.camsmanual.com.au/pdf/10_gen_req/GQ03_Schedule_A_B_2013-1.pdf
Schedule B: Line 16. shall display a blue triangle of sides 150mm indicating the location of the battery.
Nothing said about which way it has to point.
Steampunk
Postby Steampunk » Fri Jan 11, 2013 3:50 pm
JBT wrote:Put it at a slight angle and drive the scrutineers with OCD crazy.
I want to see that :lol:
find out who they are and I'll get my mate to alternate from an isosceles, scalene and acute each meet..... or after every run.
Guran
Vehicle: ND - 1.5
Postby Guran » Fri Jan 11, 2013 3:56 pm
Whichever orientation you use (I prefer pointing upwards), it's a good idea to put it on the side of the rear quarter panel, rather than on the top. Fire marshalls will be looking for the triangle when they rush to a crashed car, and they're more likely to see it from a distance if it's on the side (particualarly if the car has rolled and is on it's roof!). Of course, this advice applies to NA & NB owners only, as NCs have the battery in the engine bay. :)
SIB
Postby SIB » Fri Jan 11, 2013 4:24 pm
Given it's meant to be an equilateral triangle, not sure how you can tell which way it's pointing. :roll:
1991 LE#162 WP 1.17.700; SMPS 1.12.112
lizard
Postby lizard » Fri Jan 11, 2013 4:32 pm
SIB wrote:Given it's meant to be an equilateral triangle, not sure how you can tell which way it's pointing. :roll:
:roll:
robertq
Postby robertq » Fri Jan 11, 2013 6:03 pm
The blue triangle lets the CRASH CREW know where to find the battery, but being an ex scrutineer we just made sure the triangle was in the right place. the triangle is there to help save a car from more damage.
Postby Jeo » Sat Jan 12, 2013 12:25 am
Given the options of up or down, you tell me which way it's pointing.
Why on the boot? Magnetic P plate cut up likes the flat boot lid more than the curved side panel.
plohl
Postby plohl » Sat Jan 12, 2013 6:47 am
i have a p-plate one - it likes the side fine.
The triangles are null and void if you don't have a key in the boot so they can unlock it.
plohl
Postby Magpie » Sat Jan 12, 2013 10:18 am
What about a blue triangle on a blue MX5?
gslender
Postby gslender » Sat Jan 12, 2013 11:37 am
plohl wrote:i have a p-plate one - it likes the side fine.
Another stupid motor sport rule. So what? Boot pins too?
sailaholic
Postby sailaholic » Sat Jan 12, 2013 12:14 pm
Not Really that stupid... I know I'd want my battery disconnected in an accident. Particularly if I was trapped in the car for a while.
The alternative is a killer switch but... Some people like to run up to your car and take them out at the lights :grin:
tbro
Postby tbro » Sat Jan 12, 2013 3:26 pm
It's actually not a rule, Just common sence to have a key with a wire rope going to it so (1) you can't lose it and (2) so they can open the boot!!!!
A kill switch won't kill the battery, only the ignition circuit, re shut down the motor.
Users browsing this forum: No registered users and 297 guests
