NitroDann's Long Awaited Garage Thread
Re: NitroDann's Long Awaited Garage Thread
Postby NitroDann » Wed Jan 02, 2013 8:54 pm
Pic update, nothing everyone hasnt seen before. These things sound very naughty :mrgreen:
Props go to Works Engineering for hooking me up with a great universal intake and very high quality silicone joiners to work with.
Thanks,
brendanstacey
Postby brendanstacey » Wed Jan 02, 2013 10:02 pm
I like how you can see the works engineering logo on the intake. Thats a pretty good idea haha :lol:
Postby NitroDann » Wed Jan 02, 2013 10:18 pm
BTW there are brackets hidden under the AFM and filter housing for anyone wondering.
brendanstacey
Postby brendanstacey » Wed Jan 02, 2013 10:20 pm
there wasnt any under the afm.
Postby NitroDann » Wed Jan 02, 2013 10:29 pm
I mean that area.
In your intakes case its after the filter.
Smart alec :lol:
You have such a tidy engine bay BTW.
brendanstacey
Postby brendanstacey » Wed Jan 02, 2013 10:41 pm
Thanks, it not only looks nice but its easy to spot anything wrong such as leaks etc.
Although you cant see chewed up timing belts or the similar :|
Postby NitroDann » Thu Jan 10, 2013 10:18 pm
So with some goals in mind (an na6 in 1:0.....2's...?) the build commenced.
Getting close to the most serious gear Ive had the pleasure of designing and building.
Working out the most suitable spot for the electric water pump in massive serious turbo manifold land.
Fabbing the collectors, these have a pretty low angle for maximum flow through the midrange and top end.
Deciding where the turbo will sit, yep this spot looks like it will get us booked quick smart, it must be a good spot for power.
This shot shows the collector and front 2 cylinders, also note the flipped and welded water outlet to facilitate the electric water pump.
Heaps of room for a 4" dump pipe.
Complete manifold off the car, this setup will fit a 500+ RWHP Borg Warner EFR, down the track, hopefully within 6 months or so.
Watch this space for bulletproofing.
Finishing the welds then porting it, then off to get some good turbo studs.
Not steel, not stainless steel, but Inconel studs. Not 8mm either. 10mm Inconel studs with Stage 8 locking hardware, Resbonded to the manifold.
And then a layer of ceramic coating on the inside and 2 on the outside.
Should be enough to do the trick.
Oh and then Aero.. lots and lots of huge very serious aero.
Finish ETA, next weekend hopefully.
Postby Jeo » Thu Jan 10, 2013 10:47 pm
As always, very interested to see it continue.
Postby NitroDann » Thu Jan 10, 2013 10:58 pm
Awesome, I intend to break the NA6 GT2560 world record with this setup.
gslender
Postby gslender » Thu Jan 10, 2013 11:00 pm
What are doing for the existing water pump housing? Just a plate to block off?
G
Postby NitroDann » Thu Jan 10, 2013 11:06 pm
Water pump is in but had no blades on the pump.
It has a plate to feed the turbo where the old thermostat housing was, but it will be replaced with a welsh plug and fed from a different location.
plohl
Postby plohl » Fri Jan 11, 2013 11:06 am
Davies Craig ewp? How will you be controlling it? Pwm output? Or are you just going to run it flat out?
plohl
Postby NitroDann » Fri Jan 11, 2013 11:10 am
it runs flat out and the car has a thermostat. not ideal. iI didn't do it, it's been on this car for ages albeit in a different spot.
Postby NitroDann » Fri Jan 11, 2013 11:34 am
The muffler just arrived, this is the biggest magnaflow you can fit under an MX5.
Its just huge.
28 inches long, 5 inches tall and 11 inches wide.
I sure hope this is the right one and that it can actually fit, it sure wasnt cheap..
gslender
Postby gslender » Fri Jan 11, 2013 11:47 am
NitroDann wrote:it runs flat out and the car has a thermostat. not ideal. iI didn't do it, it's been on this car for ages albeit in a different spot.
Could have the MegaSquirt control it if you need it to... Either PWM or just on/off
G
