SE oil cooler plumbing; AN dash 8 or dash 10?
Re: SE oil cooler plumbing; AN dash 8 or dash 10?
That's overkill! All you really need is the odd squirt!
Yup I know, figured i'd share in case someone here had a similar idea.
Items like the e-Boost2 can control a water spray.
- Vehicle: Non MX-5
increase the size of the cooler if it is not cooling enough. why waste time on these little things.
Because you don't always need a larger cooler, and it's for those occasions that just a little squirt helps.
Users browsing this forum: No registered users and 93 guests
