NBA pink lights fix?
zero00
Re: NBA pink lights fix?
Postby zero00 » Sat Jan 05, 2013 11:24 am
I got an NA and an NB, both silver and I can't see 'pink' in mine! Looks fine to me!
I sometimes think the NA taillights may have been 'smoked' but not sure, depends on the angle you look at them and I prefer driving it rather than following it! Interested to hear what others say
NB is 01/00 complianced
Roger D-SUNSHINE COAST
droo
Postby droo » Sat Jan 05, 2013 12:55 pm
changing the reverse globe inside it can affect the overall reflector colour- as most every angle looking into the reflector will focus onto the bulb itself. try using a silver tinted globe if it's not already installed or sus out other options for slightly tingted bulbs for the reverse reflector.
This would be the first quickest option. The rest would involve removing the tail lights to try to get inside via the globe hole which wont necessarily work without a lot of effort.
Postby 93_Clubman » Sat Jan 05, 2013 12:56 pm
_M_ wrote:Does the smoke/tinting laminate stuff disguise this effectively?
Or a heavy duty coloured cellophane may be.
droo
Postby droo » Sat Jan 05, 2013 1:11 pm
sorry to chime in again, being globes, they can get very VERY hot on usage especially on hot days. (ambient temp + globe operating temp [are they 23W??] and lack of air circulation in the assembly). Just keep in mind that with wrapping anything on them. That said, being reverse globes, they wont be on for very long, so the potential temperature 'hit' wont last more then a few seconds in total over an entire day. Just wanted to add that for awareness sake.
Postby 93_Clubman » Sat Jan 05, 2013 1:18 pm
Was thinking of heavier grade of cellophance or similar on lens as opposed to globe. But I guess a globe could be coated with something appropriate, although could be issues with colour of light.
zero00
Postby zero00 » Sat Jan 05, 2013 1:42 pm
droo wrote:changing the reverse globe inside it can affect the overall reflector colour- as most every angle looking into the reflector will focus onto the bulb itself. try using a silver tinted globe if it's not already installed or sus out other options for slightly tingted bulbs for the reverse reflector.
Should I assume he means the reversing light lens looks pink? I just been in the garage since the last post and that's the only thing resembling pink to me :frown:
Postby Mr Morlock » Sat Jan 05, 2013 2:12 pm
your rear combination lamps emit legal signal colours ie red /amber/ clear. I am not aware of a pink tint on the outer lense but some vehicles did have this though it will still signal with a legal colour. Personally I think changing legal colours to something else is all a bit silly. Insofar as bulbs are concerned they are essentially designed so that you cannot change . However you can get a bulb that looks silver or clear but flashes amber eg diadem. These bulbs will work in certain applications provided the bulb base is compatible eg a same pin configuration. Which function are you talking about? If the external part of a lense is not to someones personal taste then it comes down to painting etc but the results may be variable and illegal because it affects light output and or colour. The lense is also hot melt glued in position and I would not remove a lense on a lamp that was not leaking around the glue track. Personally I also think the rear combo lamp on the P2 ( not sure if P1 is identical) is a great looking lamp with good function- not all makers achieve this.
I can confirm that in the old days lenses were painted in certain circumstances - with the right type of paint and almost always over a clear acrylic lense but it was an inferior process- often seen on cheaper aftermarket lamps with lowish volumes. It was inferior because the paint would fail ie fade much faster than an already pre coloured fully approved automotive grade of injection grade acrylic. As an example of poor quality materials Holdens used sub standard materials and many of the red lenses are bleached nearly white- that's because they took shortcuts- many of these cars are now not roadworthy.
If you want to know about globes check out Hella Narva Osram Philips data and also refer your handbook to see what bulbs are fitted. Quite often the bulb type is shown on the rear lamp housings.
Kev05
Postby Kev05 » Sat Jan 05, 2013 8:28 pm
_M_ wrote:those wretched pink tail lights! I don't mean faded red, I mean the crescent-shaped section towards the centre of the car. It doesn't seem to be so noticeable against darker paintwork, but on the silver it gets to me.
Can you take a photo so we can see which set of lights you're referring to?
So far, no pink lights on my stock NB8A.
Postby 93_Clubman » Sun Jan 06, 2013 5:43 pm
NB8A pink bits:
droo
Postby droo » Tue Jan 08, 2013 12:22 pm
whoa, is it getting light leaking in from the surrounding red plastics? Looks like it'd have to be somehow masked off inside and a matte painted to separate the white from the internal edging.
Are the stock lights easy to bake and separate to get inside them?
(I havent yet tried that with my stock NA lights but i have separated some aftermarket clear tail lights for another project.)
Postby hks_kansei » Tue Jan 08, 2013 12:59 pm
Mr Morlock wrote:Personally I also think the rear combo lamp on the P2 ( not sure if P1 is identical) is a great looking lamp with good function- not all makers achieve this.
P2 had clear lenses for the indicators
P1 had orange
And I think there might have also been a slight difference to the lens material, if I remember correctly the P2 lenses seemed clearer and brighter (perhaps it's just an illusion)
Postby Mr Morlock » Wed Jan 09, 2013 8:21 pm
the lense(s) are hotmelt glued or sometimes welded to the body- ie not meant to be taken apart. Lenses are not a service item.
Postby bruce » Wed Jan 09, 2013 9:02 pm
Yes, you're going to have to live with it.
I was looking at a non-MX5 today and it also had slightly pink reverse lights. Sounds like a common thing.
Postby 93_Clubman » Thu Jan 10, 2013 10:30 am
_M_ wrote:Sounds like a problem that's not going to be fixed from outside, huh?
I'll have to have a better look at it on Saturday & see if I can get inside...
I'm not particularly familiar with the NB8 rear light unit, so when I saw one on ebay yesterday with lots of pics I had a closer look:
http://www.ebay.com.au/itm/Mazda-MX-5-M ... 256bba27df
As Droo said earlier a globe of a certain tint might help, & is certainly the easiest option to try initially.
Postby Mr Morlock » Thu Jan 10, 2013 5:14 pm
the bulb is not going to do anything as the colour is in the lense ie it has a specified colour / tint. Most will probably know that lamps are frequently changed with model updates because it is a relatively cheap way to make something look different. The lamp maker for example may use much of the same tooling without having to retool the whole rear lamp. Reds and ambers are not always the same either but they do have to pass ADR's for light output etc. Lamp makers try to standardise on moulding materials to minimise SKU's and problems relating to purging moulding machines etc plus special tints can be hard to source when items are into spare parts. Too much info.
