Busted plug lead
Busted plug lead
Postby Jeo » Sun Dec 30, 2012 3:04 pm
Washed the engine bay today in my NA and she's inevitably running on three cylinders. Fired up the compressor and pulled the plug leads to blow out any water, then discovered this...
The bottom part is stuck on the plug itself. Anyone got any great ideas on how to remove it beyond a pair of really long nose pliers?
myredmx5
Re: Busted plug lead
Postby myredmx5 » Sun Dec 30, 2012 6:27 pm
Maybe the tube spanner in the tool kit will fit over the spark plug.
project.r.racing
Postby project.r.racing » Sun Dec 30, 2012 7:02 pm
dont use pliers. the plastic is brittle and hence the original cracking. any more force and you have little pieces everywhere inside you spark plug hole.
as above, try and remove the spark plug with all the plastic still attached.
Postby Mr Morlock » Mon Dec 31, 2012 2:40 pm
a useful tool are forceps - long thin nose. the other half is probably still intact. If its not assume you could blow the debris out. You can also get a variety of points and hooks etc from any of the auto places. personally I would remove the debris before taking out the plug
Postby Jeo » Mon Dec 31, 2012 3:53 pm
Can't get the socket over the plug. The plastic bit is stuck over it.
Postby bruce » Mon Dec 31, 2012 4:28 pm
Squirt WD40 into hole. Allow it to soak and soften/loosen rubber. Get a torch and wire and fish the rubber (bits) out. Blast out dry and clean before removing spark plug. Check top of plug.
ralt
Postby ralt » Mon Dec 31, 2012 5:41 pm
Hi.
Once you have removed the plastic ( you may need to obtain a set of long nose pliers- the long ones). Get a vacuum cleaner and a piece of plastic tubing ( you may need several diameters ) Put rag around tubing and put into cleaner nozzle. This should get most of the plastic out. Loosen the plug only and repeat the vacuuming this should get most if not all of the plastic out. Being plastic if a small piece gets into the combustion chamber it should not do any damage.
myredmx5
Postby myredmx5 » Tue Jan 01, 2013 9:19 am
Would you be able to fix problem by removing the cam cover?
project.r.racing
Postby project.r.racing » Tue Jan 01, 2013 3:12 pm
myredmx5 wrote:Would you be able to fix problem by removing the cam cover?
would make the job alot easier. easy just to break it up and vacuum it out them. just adds $30-$80 depending on the cover seal you buy.
Postby Jeo » Sat Jan 19, 2013 6:46 pm
For those playing at home; WD40 + extra long nose pliers got it done relatively easily.
Also, turns out two of them were busted.
Postby bruce » Thu Jan 24, 2013 5:34 pm
bruce wrote:Squirt WD40 into hole. Allow it to soak and soften/loosen rubber.
I win...a piece of broken plug lead!
Postby Jeo » Thu Jan 24, 2013 10:30 pm
Yep, full points to Bruce.
Shoot us your address and I'll happily send you both busted leads. :wink:
Users browsing this forum: No registered users and 78 guests
