It makes this noise whenever I release the clutch in every gear and in neutral.
once it's in gear, there's no problems.
I think the clutch is about 1-2 years old, maybe 7-10k kms.
vrmmmpshhh wrote:i found the problem isn't the contact point between the slave cylinder and clutch fork but the clutch fork inside the gearbox. you can either get a spring and put tension on the clutch fork so it is always putting pressure on the slave cylinder or you can do what i did and put a bolt through the clutch fork so the clearance between the 2 is minimal. i used washers for adjustment.
Users browsing this forum: No registered users and 59 guests
