Programming Remotes/Key Fob
Technical Guides primarily to do with the NB series
kenson
Postby kenson » Sun Dec 16, 2012 7:09 pm
Did this yesterday and it worked! My car only came with one remote so I sourced a second one from a forum member. Make sure the make and model numbers match!
Step One: Begin with keys out of the ignition.
Step Two: Close all doors.
Step Three: Open drivers door and keep it open!
Step Four : Perform the next steps with in 24 seconds!
A. insert key in the ignition.
B. turn key to on and off position.
C. repeat step b two more time for a total of 3 on and off key turns.
D. remove key from ignition.
E. push driver door frame button three times ( it's the black rubber button located on the drivers side door frame to let you know your doors open).
At this point, the door should automatically lock and unlock at this point to let you know that the car is in programing mode. If this does not happen, wait 40 seconds and repeat from step one.
Step Five:: All remotes need to be programed at this time including old ones that still work. Push any button on the remote two times. The door actuator should lock and then unlock or a chime will sound signaling that the vehicle has accepted the new transmitter code.
NOTE: Remember that all remotes must be programmed at this time, so if you have two remotes, then you need to do Step Five to both -- not at the same time, but one after another.
Once you're done, close the Driver's side door and test the remotes (Make sure you have your keys with you, just in case!).
Originally from: http://www.miata.net/garage/remoteprog.html
Return to “NB [1998 - 2005]”
