Hey guys, I recently fitted 20mm bolt on spacers to my NC.
The car is running 17x7.5 with 215/45/R17s.
With the spacers in the car is scrubbing in alot of places when it goes over any form of uneven road. I am planning to have the guards rolled ASAP but the main concern I have is that the tyres scrub on the inner arches when the steering wheel is locked.
So my question is how do I stop the arch scrubbing? and is it safe to continue to drive while the tyres are scrubbing?
Thanks in advance guys!
Ken
Help with tyre scrubbing!
- Jeo
Re: Help with tyre scrubbing!
Call me stupid if you must, but take the spacers off?
Jeo wrote:Call me stupid if you must, but take the spacers off?
I meant in the long run...
Has anyone been running 17x8.5s on their nc's?
- Regie
- Vehicle: NC - V8
What offset are u running?
Anything lower than +40 and u will have scrub
- Charlie Brown
One must ask why spacers?
Next, why 8.5" rims? Max legal size is 8".
On your rubbing issue, how low is the car?
Got spacers as a xmas present! Which also means I rather make them fit than get rid of them
The wheels were 17x7.5 with +45 offset, however with the 20mm spacers the wheels should be just under a 17x8.5 with +25 offset?
The car is not very low, they are sitting on eibach pro springs with OEM blistein shocks. The wheels dont scrub the guards unless going over bumps, they do however scrub the arch liners when turning...
- Regie
- Vehicle: NC - V8
Ahh that's right, you bought Neil's old rpf1's
Yep +25 way too much!
- Vehicle: Non MX-5
so what if they are a xmas present? if you wanna get rid of your scrub, get rid of the spacers.
- Regie
- Vehicle: NC - V8
kayye wrote:The wheels were 17x7.5 with +45 offset, however with the 20mm spacers the wheels should be just under a 17x8.5 with +25 offset?
the wheels will just be 7.5 with a +25 offset......
run some 185-195 tyres
Just get rid of the spacers.
20mm is putting a huge load on bearings and studs.
Probably diving all over the place too.
10mm spacer maybe...
Rob
Users browsing this forum: No registered users and 226 guests
