Question about this little bulb
- tescoking
Do you guys know what size is this bulb? Where can I find it? Will I be able to find a blue one, if not what can I possiblely do to change the colour to blue? Many thanks.
Re: Question about this little bulb
Looks like either a T5 or T3 bulb. Alternatively you can just replace the red condom that's on top of the bulb with a blue one.
- tescoking
so is that bulb by itself or the whole black stand with the bulb together? and where can i find that bulb and the blue rubber thing?
- aka_juffa
There has been a number of previous posts in the forum about changing the OEM dash bulbs for LED. The idea being that you can buy replacement LED bulbs in various colours.
Here is a couple of threads which may assist you.
viewtopic.php?f=55&t=50281&hilit=bulb
viewtopic.php?f=55&t=37225&hilit=bulb
Hope that helps.
J.
Hope that helps.
J.
- tescoking
checked already, but those are something different, mine is from the lower dash, also I don't think that is T10 or T5, because I have changed my dashboard light too, the one I am holding is from the place that you adjust the brightness level for the dash, and this is the little bulb behind the controler, I just don't know what size is it.
Finally had some time to look properly.
Have a look here:
http://autolumination.com/74.htm
Half way down the page. They are called Neo-Wedge bulbs. You'll need either a T3 or T4 base. Pretty sure it's probably a T3.
Otherwise just go to your auto store and ask for rubber bulb covers or condoms. Bring the bulb along and they'll know what you're after.
Have a look here:
Repco will have one. Just go to the Parts counter.
Bursons might be a go- they are more savvy on spares than Repco- look on line and see if Narva list it in their catalog
- tescoking
thank you guys, you've really helped me out a lot, much appreciated, case close
Users browsing this forum: No registered users and 150 guests
