Help with tyre scrubbing!
kayye
Postby kayye » Tue Dec 11, 2012 6:41 pm
Hey guys, I recently fitted 20mm bolt on spacers to my NC.
The car is running 17x7.5 with 215/45/R17s.
With the spacers in the car is scrubbing in alot of places when it goes over any form of uneven road. I am planning to have the guards rolled ASAP but the main concern I have is that the tyres scrub on the inner arches when the steering wheel is locked.
So my question is how do I stop the arch scrubbing? and is it safe to continue to drive while the tyres are scrubbing?
Thanks in advance guys!
Ken
Re: Help with tyre scrubbing!
Postby Jeo » Tue Dec 11, 2012 7:53 pm
Call me stupid if you must, but take the spacers off?
kayye
Postby kayye » Tue Dec 11, 2012 8:21 pm
Jeo wrote:Call me stupid if you must, but take the spacers off?
I meant in the long run... :?
Has anyone been running 17x8.5s on their nc's?
Postby Regie » Tue Dec 11, 2012 8:43 pm
What offset are u running?
Anything lower than +40 and u will have scrub
Charlie Brown
Postby Charlie Brown » Tue Dec 11, 2012 10:20 pm
One must ask why spacers?
Next, why 8.5" rims? Max legal size is 8".
On your rubbing issue, how low is the car?
kayye
Postby kayye » Wed Dec 12, 2012 1:52 am
Got spacers as a xmas present! Which also means I rather make them fit than get rid of them :?
The wheels were 17x7.5 with +45 offset, however with the 20mm spacers the wheels should be just under a 17x8.5 with +25 offset?
The car is not very low, they are sitting on eibach pro springs with OEM blistein shocks. The wheels dont scrub the guards unless going over bumps, they do however scrub the arch liners when turning...
Postby Regie » Wed Dec 12, 2012 7:53 am
Ahh that's right, you bought Neil's old rpf1's
Yep +25 way too much!
project.r.racing
Postby project.r.racing » Wed Dec 12, 2012 9:49 am
so what if they are a xmas present? if you wanna get rid of your scrub, get rid of the spacers.
Postby Regie » Wed Dec 12, 2012 11:45 am
kayye wrote:The wheels were 17x7.5 with +45 offset, however with the 20mm spacers the wheels should be just under a 17x8.5 with +25 offset?
the wheels will just be 7.5 with a +25 offset......
run some 185-195 tyres :)
Sailor
Postby Sailor » Wed Dec 12, 2012 12:13 pm
Just get rid of the spacers.
20mm is putting a huge load on bearings and studs.
Probably diving all over the place too.
10mm spacer maybe...
Rob
