Clicking and high oil pressure! Help!
- Vehicle: Non MX-5
Re: Clicking and high oil pressure! Help!
i'd be tempted to put one of those oil flushes through it also. 16 month old oil has gotta be all crushed up inside the oil galleries by now.
- MNC23
- Learner Driver
Thanks for the tip racing driver.
If the HLA clicking noise persists you might want to consider using Nulon Lifter Free - a number of forumites have found it useful:
search.php?keywords=lifter+free&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
- MNC23
- Learner Driver
Hi guys,
Minxie had an oil and filter change the other day. Would have got a full service but couldn't afford it. Anyway, the oil pressure was immediately back to normal. We're keeping her at home now so gets dríven more often. I've noticed the last couple days when I've taken her shopping that the oil pressure is up around just over 4 until about 10 minutes of driving then its back down around 2. Is this ok? Does it mean she needs something else done or is it normal? Will keep the nulon lifter in mind for the next oil change. There is no clicking now
Christie
Christie
MNC23 wrote:I've noticed the last couple days when I've taken her shopping that the oil pressure is up around just over 4 until about 10 minutes of driving then its back down around 2. Is this ok? Does it mean she needs something else done or is it normal?
Is this happening at idle or at higher revs? Oil pressure is lower at idle than at higher revs once warmed up.
- JBT
MNC23 wrote: I've noticed the last couple days when I've taken her shopping that the oil pressure is up around just over 4 until about 10 minutes of driving then its back down around 2. Is this ok?
Normal. Oil pressure will reduce as revs reduce and/or as engine temp increases
- MNC23
- Learner Driver
Thanks guys. Glad it's normal.
