240
Postby 240 » Thu Nov 15, 2012 10:08 pm
Got home from driving it 7000kms up to Noosa along the east coast and back to Adelaide through the riverland. It's been a good 3 weeks with some great roads and a handful of battle scar stone chips. Worth it.
240
Postby 240 » Thu Nov 15, 2012 10:14 pm
(2300 kms in the last 30 hours hurt a bit though)
sailaholic
Postby sailaholic » Fri Nov 16, 2012 9:39 pm
Put fuel in it for the first time in 9 months and drove it to work
zephyrus17
Postby zephyrus17 » Fri Nov 16, 2012 10:18 pm
Why so long?
Momo (aka 1990 white NA6)
Matt
Postby Matt » Fri Nov 16, 2012 11:18 pm
Pulled out the oem head unit and fitted a new one with a coin tray beneath it.
Guy_Coles
Postby Guy_Coles » Sat Nov 17, 2012 3:42 pm
FINALLY installed my Okuyama Carbing Rear Strut brace with Regie. Then had lunch and coffee with Regie and Sailor.
2006 Black NC Soft Top with lots of Mods -
WP: 1:12.26 , SMP South 1:106.25 - 11th outright in Victorian 6 Hour 2015
http://privasec.com.au//
LuckyCat
Postby LuckyCat » Sat Nov 17, 2012 4:50 pm
Getting some under bonnet bling from IL Motorsport....
chris
Postby Regie » Sat Nov 17, 2012 5:12 pm
Guy_Coles wrote:FINALLY installed my Okuyama Carbing Rear Strut brace with Regie. Then had lunch and coffee with Regie and Sailor.
and now I want one! what a difference!!!!!
El Jay
Postby El Jay » Sat Nov 17, 2012 10:45 pm
Fitted new Kumho ku31 tyres all round. It was too bad that there was lots of rain today, as I didn't get a chance to properly test the handling improvement :( I noticed however that the new tyres were much more comfortable and soaked up bumps a lot better.
I also initially had some reservations about getting the tyre store to do the wheel alignment, since the guy first thought the castor wasn't adjustable :roll: They got fairly close to the specs I gave them, so can't complain too much given the price paid.
Next on the list is sorting out the suspension; I think the mod bug has hit me! :x
sailaholic
Postby sailaholic » Sat Nov 17, 2012 11:45 pm
zephyrus17 wrote:Why so long?
Turns out you get awesome economy when the engine isn't assembled.
zephyrus17
Postby zephyrus17 » Sun Nov 18, 2012 3:54 pm
Yesterday night found the temp gauge to be super high, almost 3/4 H. Today bought 2x 2L demineralised water from Coles. Started pouring...... 1 bottle gone! 2nd bottle was almost empty until the radiator was full. Can't believe the radiator was so empty.
Need to do a rad flush soon
kenson
Postby kenson » Sun Nov 18, 2012 11:13 pm
Interesting few days with a few face-palm moments:
1) Found out air con compressor was leaking - got that fixed. New compressor in!
2) Car came back and I noticed it was running v hot. After some investigation, the radiator cooling fan wasn't kicking in. Condenser fan was running though.
After checking wiring relays and fuses (they were OK), I decided to check to see if the fan spun. Turns put the plastic bracket that goes around the fans was dislodged and stopped it from spinning! Here I was measuring temperatures, checking wiring etc! Doh haha.
3) I also noticed my turbo wasn't boosting as much. I thought it may have been related to the heat and my intake but turns out they didn't put back the AEM intake properly.
4) OK so power back and then gone. I noticed "farting" noises from the engine. Looks like the standard plastic BOV is dead. Ordered a replacement Turbosmart.
5) Belts weren't squeaking before but now they are after changing out the compressor. Another job for next weekend :)
Hjt
Postby Hjt » Sun Nov 18, 2012 11:20 pm
I bought a hard top, used a friends mx5 to bring it home since my cars still getting work done :)
superfluous2
Postby superfluous2 » Sun Nov 18, 2012 11:24 pm
Used some headlight restorer stuff to clean up my headlights :D
NB8A - Winton [1:49.2] Wakefield [1:16.8]
Nixon
Postby Nixon » Mon Nov 19, 2012 2:29 pm
Removed stock na spoiler tacked holes up and made good yesterday, given it some bog for the low spots today and laying down some primer in an hour or so.
'89 Eunos Roadster "MMX52"
