Hi all
My mechanic has a New Zealand registered NC that he is readying for registration in Australia. Apparently it has Bilstein shocks (not sure if they are exactly the same shock as my NC, which also has Bilsteins). He contacted Mazda and gave them the part numbers off the shock and was advised parts could take a while.... Does anyone know if they are the same Bilsteins as fitted here? If so, can you suggest where they may find some, as apparently Pedders could not help them either. I wouldn't bother, but these guys are good mechanics and really look after us well.
Thanks!
Bilsteins on New Zealand NC
- Noddycar
1993 MX-5 Limited Edition - my original Noddy Car
2010 Roadster Coupe Sport - the more civilised (but still fun) daily driver
Re: Bilsteins on New Zealand NC
Jonosx on here works for Heasmans in Sydney: <jonathon.mckinnon@bilstein.com.au>
viewtopic.php?f=30&t=49620&p=622933&hilit=+heasmans#p622933
The OEM Bilsteins on the NC are not a great shock, the normal shock does a better job particularly on the rear.
They will all be the same fit.
I'd suggest he use aftermarket shocks like the Tokico HTS from Shox.com as they are a perfect match for the OEM springs.
Rob
- Noddycar
Thanks all. Sorry, just realised I forgot to reply after reading the posts!
Users browsing this forum: No registered users and 198 guests
