Hello,
I have a b6t engine in my 323 and I have brought the big nose crank as a upgrade because my small nose snapped.
I would like someone to help me locate the correct parts
I found this on a old post regarding what I need
>>>>>>>>>>>>>>>>>The crankshaft, pulley bolt, cam sprocket, front seal, pulley, spacer, and oil pump must be replaced as a set<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
I have the big nose crank and oil pump to suit already.
Where do I get the other parts?, Is that everything I need?
What are the part numbers? I do not want to make the mistake of buying small nose parts.
Big nose crank parts needed.
Re: Big nose crank parts needed.
Some are at mx5parts.co.uk and the you'll need to go to Mazda for the rest.
e.g. http://www.mx5parts.co.uk/crankshaft-timing-belt-pulley-bolt-mk1225-p-1398.html
You're missing a new woodruff key from your list. This is the most important part in the whole job.
These should help you too. Good luck with it.
http://www.miata.net/garage/90-99Parts/index.html
Users browsing this forum: No registered users and 324 guests
