Hello All.
I am looking to delete the 5th injector in my supercharger system and opt for 4 bigger injectors.
Does anyone recommend a particular brand?
I have been recommended these http://www.miataroadster.com/fuel_injec ... 62736.aspx
Hoping for some input from people who have got aftermarket injectors and boost.
Thanks.
which injectors
- 16bit
which injectors
- Dweezle
Re: which injectors
I think it will depend on your power goals?
I know people seem to doing ok with the RX8 Injectors at 200odd whp.
They are 450cc.
Plug and Play
http://949racing.com/Denso-195500-4450-injectors.aspx
They are 450cc.
Plug and Play
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- 16bit
Re: which injectors
you have probably asked a second question for me!
i am only producing about 200whp at the moment but want to future proof for 400 crank hp.
i have used a few online calculators and they say to aim for about 775cc injectors at 80% duty cycle.
is it ok to run such big injectors while I am making the lower power figure?
Re: which injectors
Also I have read numerous times that the spray pattern is different on RX injectors, this should be confirmed prior to purchasing any.
Re: which injectors
They are different but they work fine.
Just buy ID1000's and be done with it mate.
- Vehicle: NA6 - Turbo
Re: which injectors
NitroDann wrote:They are different but they work fine.
You will get OEM like idle even with the 1000cc's
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
- zoomzoom
Re: which injectors
Or buy FIC as linked above from miataroadster for less $$ and get great service and the same (bosch EV14) injectors in a better selection of sizes. FYI I am running 775, that should be fine for 400 CHP.
Tim
Tim
- 16bit
Re: which injectors
sweet, modern german ones it is! thanks everyone.
